Question about Air Tools & Compressors
I have water in my oil?
I'm not sure how water got into my oil, please help.
Pressurised oil coming out of the dipstick help please
check the oil level to make sure it isn't overfilled, also check the seal on the dipstick as their is pressure in many modern internal combustion engines and if the seal isn't good oil can come out. It is also possible that you have a blown head gasket, check water for oil and oil for water.
Oct 10, 2016 | Cars & Trucks
Why is my car not starting after overheating?
The first thing to check is the oil. If there is no oil in the motor, the first thing you want to do is to get some witnesses, hopefully someone (s) who know how to check the oil level. Then have the same person looking under the motor to see if the oil drain plug (or bolt) is still installed on the oil pan. Remember NOT TO ADD NEW OIL to the motor if it has no oil.
If the motor has no oil, make sure you don't start nor drive the car. Contact the shop that supposedly replaced the oil, and make sure that your witnesses back-you up when you need them. Don't let the shop take your car and then tell you that the motor had oil in it.
If the motor has oil in it, then do some of the things other posters have told you to do.
Mar 22, 2016 | Cars & Trucks
Engine lite on allso my i have coolant problem every i saw greese in my coolant i cleen it it come right back help me please
Doesn't sound to good. A cracked head between cylinders will put oil in water...Check your oil dipstick to see it water is getting in oil.
Aug 12, 2013 | 2003 Chevrolet Malibu
Need help Drive through flood covering road Next day get management light on and lack of power and grey smoke Help please
sound like water got in the engine.check air filter housing check engine crankcase oil level see if water got in crankcase raising oil level. if oi look contaminated change oil and oil filter.
Nov 23, 2012 | Cars & Trucks
2002 silhouette that has oil in the coolant but no water in the oil. I had the head gaskets and intake gaskets replaces 6 months ago. not sure what else it could be
Would have to be head gasket has fail letting oil into water jacket.. My suggestion. Does not have to be water in oil to be blown....Sorry i wpild sat head gasket......Let me ask you when the gaskets was changed did you have the head checked and did you have head bolts replaced?? Head if not cracked my need plained.......hope this helps and good luck...Please rate my posting
Aug 15, 2012 | 2002 Oldsmobile Silhouette
Hi ...I have Sperre Reciprocating Air compressor...i have problem that crank case oil turns milky in color ...its sure tht this is sign of condensation or water contamination in oil but...
That is moisture in the pump oil. Not good. You need to drain it and replace it or cook it on your stove to boil out the moisture. Cooking the oil is dangerous and the heat must be just enough to make the water boil up and out but not take the the oil into a flammable temperature range or overheat the oil. Not going to smell good cooking either.
Jan 28, 2011 | Air Tools & Compressors
Why is the transsmition oil and water are mix together
The Transmission oil passes through the radiator to keep it cool , If the pipes inside the radiator are damaged then water can enter into the trans lines causing the problem you are having.
Get the radiator checked and repaired/replaced...
Also get the Trans fluid changed as water can damage the trans internals.
Hope this helps.
Jul 21, 2009 | 2000 Volvo S80
No oil but no warning night came on
check to make sure your oil cap is on and make sure your oil filter is on. let it sit in a driveway or parking spot put oil in it and let it run for a while look underneath to see if there are oil spills, then contact your local mechanic.
Jun 26, 2009 | 1983 Oldsmobile Cutlass Supreme
My catera has milky creamy stuff inside the oil, every warning light is on, but now it doesn't start at all, There's also alot of loose wires
there is water in your oil i am not sure how to get it out you might try to change the oil but i am not sure if that will help or not but i do know for sure that you have water in your oil
Jul 22, 2008 | 1997 Cadillac Catera
Air Tools & Compressors Logo
23 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
