Question about AUVIO Bluetooth Headphones
Bluetooth earpiece wont connect to computer
I do the right things to ensure it would connect. it connected to my phone but why not my laptop? the driver softwear wont install.
The headset connects to the phone but then it says connecting and then comes up bluetooth connection failed and it wont work hands free, it has the blue symbol on my phone screen but wont it wont connect...
I would suggest turning off your phone and headset. Turn your phone back on and put the headset into pairing mode (the headset needs to be turned off when starting the pairing mode) pull up your menu on your Bluetooth phone and try reconnecting the two again.
Below is the Explorer 320 User's Guide for more information.
Plantronics Explorer 320 User's Guide
Good luck from Headsets Direct!
Apr 27, 2011 | Plantronics Explorer 320 Wireless Headset
Can I connect my garmin nuvi 1310T to my Jabra BT2070 bluetooth headset earpiece
You probably cannot. Some bluetooth devices act like phones, and others act like earpieces. The Garmin acts like an earpiece to offer a hands-free speakerphone while driving. Your Jabra earpiece wants to pair with a phone, not other earpiece-type device.
Apr 18, 2011 | Garmin GPS
My motorola cliq wont send anything bluetooth at all and it wil pair and find devices but not send anything and will say other device is not connected
Unfortunately....YOU CANT send anything by way of Bluetooth. I love this phone & this is the one thing i HATE. Used to do it all time on my old phone,I even called Tmobile Tech support. They said No go..Thats the only flaw in this phone. They said it will recognize the devices which mine did also. The only thing it can do is bluetooth earpieces..But Sending/Sharing with Bluetooth----NO Can Do..Call tech support if ya like they will tell you same thing. I was soooo dissappointed. I used to share files & such with my friends like that.
Sep 03, 2010 | Motorola Mobility CLIQ Cell Phone
Earpiece not working after hooking it up with a bluetooth speaker
Go to Bluetooth settings and turn on Bluetooth.
The paired devices will be shown.
Delete paired device or unpair device .
This should solve the issue .
Since the mobile is paired with the Bluetooth speaker every time a call comes in the phone automatically connects to the Bluetooth speaker.
Switching off the Bluetooth speaker may also work.
Mar 28, 2017 | Motorola Mobility ROKR E8 Cellular Phone
How do I sinc my samsung hd 8910 to my apple mac
If you are trying to connect using bluetooth you can browse the phone. Go to system preferences and then click on bluetooth at the bottom right of this window
underneath the plus sign is "show Bluetooth status in the menu bar", click on this and it will make it easier to connect to your phone the next time you want to connect. Now click on the plus sign (+) this will bring up the Bluetooth Setup Assistant. click on continue select mobile phone. The blue tooth will start scanning (please ensure that your blue tooth is switched on your phone and ensure that it is discoverable). Hope this helps.
Nov 11, 2009 | Apple MacBook Pro Laptop Computer with...
Bluetooth connects to LG Vu phone but does not work
I would suggest taking the battery out when the phone is powered on. Replace the battery and try to re-pair the set.
If that doesn't work, then its likely the bluetooth module in your phone is broken. You can validate this by pairing the bluetooth with another handset.
Jun 30, 2009 | LG Shine CU720 Cellular Phone
Plantronics Explorer 220 no longer connects to Blackberry Curve
You can have the two devices connected, but still get your sound through the phone. During a call (maybe call your voicemail or an automated number, just to make a call) try holding down the answer/end button on the earpiece until it beeps, and see if the sound switches from the phone to the earpiece. You can also try pressing the speakerphone button on your phone during a call to switch the call to the earpiece.
Did either of those ideas work?
Jan 26, 2009 | Plantronics Explorer 220 Bluetooth Headset...
LG Shine KE970 Bluetooth issues
the pass code is always zeros trust me
Nov 07, 2008 | LG Shine KE970 Cellular Phone
H350 bluetooth headset can't connect to laptop any solution connect to a motorola bluetooth headset how do I get my Motorola H350 bluetooth earpiece to work with my laptop?
Do you have the Jabra bluetooth part that goes into your computer? You have to go to your phone settings under bluetooth and make it sync up. Your phone will sync, not your headset. You are trying to sync the wrong thing.
May 04, 2008 | HP Pavilion dv6000z Notebook
Bluetooth of compaq nc8230
there is normally a switch on the front of the laptop or a function key on the keypad to turn on/off the bluetooth, so check both and also when you turn it on, ensure in the the settings that the laptop is discoverable to other bluetooth devices, as your phone wont find it otherwise. If bluetooth is enabled on your notebook it should apear in control panel, so go to my computer>right click to properties>hardware tab>device manager, and look down the list for network adapters and click on the '+' sign and see if your blutooth adapter isnt dissabled with a red cross, if so right click anf select enable or has no driver installed; showing a yellow exclamation mark, if so right click and select update driver.
Jun 12, 2007 | HP Compaq nc8230 Notebook
AUVIO Bluetooth Headphones Logo
32 people viewed this question
Top AUVIO Audio Players & Recorders Experts
 Mikey
Mikey
Vladimir Frolov
Phillip Hicks
Phillip Hicks
Are you an AUVIO Audio Player and Recorder Expert? Answer questions, earn points and help others
