0160 DMI table was destroyed
What to do?
Tip
How to remove the text from the Desktop icon
Desktop is the interface of Windows, which contain the icons, taskbar etc. that allow the user to interact with the computer to perform different operations. Usually the picture of icon represents its purpose so if you want your desktop looking very clean then you can remove the title under the desktop icons. May be you are thinking it is so easy, just go to rename option and set blank name or single spacebar entry but the problem is this, windows will not allow you to set blank name or name with single spacebar entry. Here interesting thing is this; window will allow you to use the ASCII code for a space, which is 0160.
First clear all the text from that icon
Now type the ASCII code, simply hold the Alt key, type the number 0160 from the number pad and release the Alt key then press Enter button to finish the process.
But if you want to remove the text of multiple icons, then repeat the above process with adding one extra ASCII code for second icon, (for example for second icon you type the 0160 twice and for third icon type 0160 three times with Alt key and so on).
on Feb 26, 2010 | Computers & Internet
What should I clean my massage table with?
I always clean my massage table using a spray bottle. Fill a small spray bottle half way up withwater. Then, fill the next 25% up with akitchen disinfectant. Spray the tableliberally and then dry off very well with a towel. This way, you can kill all the germs on thetable but you won't destroy the vinyl with bleach.
May 29, 2012 | Furniture
When i boot the computer it says verifing dmi pool
Hello there and welcome to fixya
A. DMI or DesktopManagement Interface (pdf) is a layer of abstraction between system components and the software that manages them. The System Management BIOS (SMBIOS) is an extension of the Basic Input Output System (BIOS) that formulates and delivers this information to the operating system. The pool data is the information. In short, when the BIOS is "Verifying DMI pool data" it is verifying the table of data it sends to the operating system (Windows, etc.). If it isn't sucessful, it should return an error. Wait a reasonable period of time for it to finish. It may make take some time or it may be stuck. Possible fixes:
1. If you changed the hardware just before this problem occurred (e.g., installed a new hard disk drive), unchange it.
2. If you installed a new hard disk drive, set the motherboard CMOS Setup to Auto for the drive type. You may have to disconnect the drive first.
3. Enable "Reset Configuration Data" (may be "Force Update ESCD" in some CMOS Setuups) in the motherboard CMOS Setup PNP/PCI configuration. (Rebooting will automatically disabled it after it has done its thing.)
Oct 15, 2011 | E-Machines eMachines Desktop PC
Hi all you get is this motherboard manual? Block
Omlouváme se, pokud si nemůžete sotva pochopit mě, jak jsem pomocí překladatelské služby.Stačí jít sem: http://www.acer.cz/acer/service.do?LanguageISOCtxParam=cs&miu10einu24.current.attN2B2F2EEF=3739&sp=page15e&ctx2.c2att1=4&miu10ekcond13.attN2B2F2EEF=3739&CountryISOCtxParam=CZ&ctx1.att21k=1&CRC=1160877988 a klepněte na tlačítko Dokument pak uživatelský manuál a download. Doufám, že to pomůže.
May 29, 2010 | Acer Computers & Internet
I nedd bios upgrade for my laptop clevo m220s
It seems it is a product of SiS. Visit http://www.sis.com.tw and search the BIOS upgrade in the download or support section. If SIS has launched any upgrade for your product, it will be available there. (ehteshamhusain@gmail.com)
Apr 04, 2009 | Computers & Internet
Driver provlem
Is it possible it's a Sound Blaster Audigy?
http://www-307.ibm.com/pc/support/site.wss/MIGR-51794.html
Hope this helps!
Mar 28, 2009 | IBM Computers & Internet
Where can i get the sound driver for my motherboard intel d865gkd
The sound driver you need is the SoundMAX Cadenza driver. according
IBM YOUR IS http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-51191&velxr-layout=printLenovo
Thank you.
Mar 26, 2009 | Computers & Internet
Air flow hockey table
We made a fixture that allows us to clean the table top. We took a piece of wood larger than the fan opening, drilled a hole in it, and installed an air fitting for use with our home air compressor. WIth the fans removed, we run the compressor and hold the fixture against the bottom of the table. That forces all that air to exit out the table surface. To concentrate the flow over problem areas we cover sections of the table during the process. Also, you may need new pucks too if they are old and worn.
Dec 09, 2008 | Dmi Sports Air Hockey Table Dmi Goal Flex...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
