Question about Canon PIXMA iP4300 InkJet Photo Printer
Canon not recognising cyan cartridge
Hello i have just done a bit of printing and I have just had a msg appear saying ink cartridge not reconised. I went out and bought a new Cyan, as that is the cartridge thats not working and i have the same dram!
  • 1 more comment
  • thePianoMan Nov 08, 2007
    I had this problem, sent it in for service and they replaced the cyan cartridge and said that all was well. A few months later, it's starting to do the same thing again, I have to keep reinstalling the cyan cartridge :( I find I can sometimes fix it by turning off a small desk lamp (not fluorescent) that is next to the printer - maybe it's a problem with the optical ink level sensor not being aligned correctly?
  • Anonymous Nov 28, 2007
    Magenta not recognized. Will work once after doing a "nozzle head cleaning", then goes back to same problem. 15 orange blinks.
  • Anonymous Apr 12, 2008
    Estou com o mesmo problema. Até a dor do cartucho com problema é o mesmo: cyan. Já li várias sugestões: desinstalar e reinstalar a impressora (painel de controle-impressoras e outros hardwares); desinstalar e reinstalar TODOS os cartuchos e a cabeça de impressão; e substituir o cartucho defeituoso por um outro ORIGINAL. Acontece que esse problema tem acontecido com VáRIAS impressoras IP4300. Logo, é um defeito de fábrica ou um golpe da empresa para nos obrigar a comprar maiscartuchos. Até agora nenhuma solução definitiva e com boa justificativa me foi apresentada.
    HELP US !!!
    Problem Solver:
  • 12 Answers
Posted on Dec 31, 2007
I have installed a replacement ink cartridge in my MP560 and it is saying ink tank is not recognised and refusing to print. What can I do? It seems like a bit of a con to force you to use Canon inks which...
hi,restart your printer with the printer replacement inside and wait for the error message to appear once error appear,press and hold the stop button untill the system re this process the main ink detector will be reset and will recognized the new replacement cartridge
note:press and hold the stop button and never release the button until power restarted.
If you want to be able to save on your cartridge you can refill your empty cannon cartridge with ink
here a video on how to refill the cartridge.
Jun 28, 2011 | Canon MP560 All-In-One InkJet Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
My printer has stopped printing from the cyan ink
Hi, did you let the ink cartridge dry out completely before inserting a new cyan cartridge???
If this is the case you may have a bit of trouble getting the ink through the have to persevere with deep cleaning and/or head cleaning...
if that does not work you may need a new printhead...which is usually dearer than a new printer...
I would also take the printhead out and clean the contacts with Isopropol not get finger prints on the contacts...that will stop it very quickly...
just a thought...did you remove the sealing tape over the airholes and bottom feeder hole on the cartridge???
if the airholes are sealed the cartridge pulls a vacuum and the ink will not flow...
hope this helps you...
Dec 06, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I haxe recently purchased a brand new canon mp530 that is still under warranty.I don't allways have the problem but often enough for it to be one.Adout 90% of the times I try to print I get an error...
I notice that you saw error message 'check ink c'. This means the printer want you to observe cyan ink cartridge. so,what happen before this message appears?. Please make sure that cyan ink is not empty. if you are sure the ink not empty,then remove cyan ink and reinstall it,else try dry clean ink cartridge contact or you may use contact cleaner before reinstall it. if you have have another cyan ink cartridge that is in good condition,compare it. if this works,means cyan ink cartridge is faulty then you need to replace with the new one. but if the problem still persist,it may caused by carriage unit or logic board problem.
Soruce: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon iP1800 not recognising cartridges
5 flashes says the printhead is not installed properly, you may need a new printhead,
Jul 27, 2009 | Universal Office Ink Tank Cartridge for...
Check ink U071 cyan
Are you using genuine ink cartridges? If not, then perhaps there is no microchip on your ink cartridge. You can take the old chip off your used cartridge and put it on this cartridge and see if this solves your problem.
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Only Prints in Magenta
The cartridges may still be at fault, or there is a problem with the processor board in the printer. I have also seen problems with the ink jets in these.
Jerry G.
Apr 19, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Cyan ink tank not recognised
I phoned Canon Tech Support Center this morning. They had me replace the ink tank giving me the U150 error code and are sending me a replacement tank. HOPEFULLY this will solve the problem.
Oct 27, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA  iP4300 InkJet Photo Printer Logo
378 people viewed this question
old marine
old marine
