Question about Refrigerators
The model # KBF A25ERSSo1
Kitchen Aid Refrigerator - Model #KBF A25ERSSO1
  • richie46 Apr 01, 2014
    Hi Jacqueline Burkes, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
  • 1314 Answers
SOURCE: kitchen aid refrigerator model KSRS22Q
it should be on the bottom where the kick plate is and will be a round piece that you turn and remove
Posted on Mar 03, 2008
  • 142 Answers
SOURCE: Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Posted on Oct 01, 2008
mgprice
  • 744 Answers
SOURCE: Problem with Kitchen Aid side by Side
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 11, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchen Aid model KSRJ25CNST00
HI. your unit is equipped with a defrost thermostat that is wired directly to the control board/PCb, and linked to the defrost element as well. this thermostat has failed, in return, not allowing the proper transfer of correct temp readings that the control uses to calculate the proper defrost cycle.
Replacing the defrost thermostat(Bi Metal) will fix this issue.
Posted on Sep 06, 2009
Tip
Important Info need when asking a question about your Major Appliance
Please get the model From your appliance before you post your question. We can not do a thing for you with out that model. Thanks you so much. We are trying to help you.
on Mar 15, 2015 | Electrolux 78956 Frigidaire GE Maytag Jenn...
Kitchen aid ksss42 not cooling fan runs
With this particle number you gave there are over 40 different models. So I seek a better model number or a complete number to assist you better. Some models had a inverter to control the compressor and I have seen failure due to heat or surges. But without a model number to verify I can't and won't direct you on a fish hunt without the correct information. Get back to me with more information please.
Aug 25, 2014 | KitchenAid Kitchen Aid 42" Built In...
Where is the filter located on the KSR52206WH00 model 98 Kitchen Aid Refrigerator?
I would suggest you look inside the refrig compartment and get the correct model #.
The one you put in the question does not exist.
May 23, 2014 | KitchenAid Superba Architect KSCS25INSS...
Model KBF A25ERSS01 - S/N ECT2510800
I am not familiar with this refrigerator, but what you describe can happen if the refrigerator uses a motorized damper to control the refrigerator temp by varying amount of air from the freezer that circulates in the refrigerator compartment. If the damper door is stuck in the open position or broken, the refrigerator temp will not be controlled and freezing can occur in the refrigerator compartment.
Apr 01, 2014 | KitchenAid Refrigerators
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
My kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
Aug 29, 2009 | KitchenAid Refrigerators
Compressor runs continuously, and center bar (heat dissipator) is extremely hot to touch.
Molly, The hot bar is a normal part of the sealed system (compressor) operation. The relay they told you about is on the back of the compressor and I would not recommend you changing that. The refrigerator is a balanced system, the freezer air removes the heat from the refrigerator side. If the compressor runs all the time, look for food close to the edge and not letting the doors close completely. Move items back. Don't over pack the freezer, the air must circulate. The refrigerator of today runs longer and uses less power that the old refrigerator. If you are still having issues with this model call a authorized Kitchen repair person in you area and ask how much they charge to come to your house and give an estimate.
May 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
