Panasonic sc hc25db
NO DAB RESPONSE
2 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: since a storm the dab
It is a loose connection or cold solder and cleaning problem this is the main caused of no sound..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 10, 2008
Panasonic SA-PT467 I am trying to find the original description of my DVD home theatre system. I cannot find anything about it!!
Manual and Review
Panasonic SC-PT467 Manuals
https://www.manualslib.com > Brands > PANASONIC Manuals > Home Theater System
  1. Cached
Manuals and User Guides for PANASONIC SC-PT467. We have 1 PANASONIC SC-PT467 manual available for free PDF download: Operating Instructions ...
Panasonic SC-PT467 Home Theater System ' Product overview ' What ...
www.whathifi.com > Products > All-in-one-systems > Surround systems
  1. Cached
  2. Similar
Panasonic SC-PT467 Home Theater System overview from the experts at What Hi-Fi? - compare latest prices, see user reviews, and see specs and features.
Panasonic SC-PT467 5.1 Surround Sound reviews, prices and deals ...
https://www.reevoo.com > ... > Sound channels : 5.1 surround sound > Panasonic
  1. Cached
  2. Similar
Rating: 8.4/10 - ‎33 votes - ‎Price range: Compare prices Latest Panasonic SC-PT467 reviews, ratings from genuine shoppers. Find best deals and buying advice from consumers on Panasonic SC-PT467 from Reevoo. Surround sound effect‎: ‎8.8 Clarity of instruction manual‎: ‎6.9 Sound quality‎: ‎8.4 Panasonic SA PT467 Google Search
Dec 05, 2016 | Panasonic Audio Players & Recorders
SC-HC35DB DAB RADIO HAS STOPPED WORKING , ALL OTHER PARTS FINE ,
You need to tunr the power off at the wall socket. Leave the unit off for at least 5mins. Then whilst holding the power on button on the unit down, turn the power back on at the socket, keep the power button depressed for at least 5secs. When you release it you should see -----------------, in the display. The unit has just been reset to factory mode. All features should now be present again. Hope this helps.
May 02, 2012 | Panasonic Audio Players & Recorders
I HAVE A SC-HC30DB SYSTEM AND IT'S NOT LETTING ME IN THE DAB MENU,DAB NOT WORKING ALL WORKING OK OTHERWISE.
I had the same problem - you can fix with a system reset. Unplug the unit at the wall and wait 2-3 mins, then plug in and switch on while holding the power button - the display will be blank for at first, but will eventually display '---------------------'. Release the power button and switch the unit on as normal. Press the Dab button and the unit will start to auto-search for channels. Give it a few minutes and you'll be back in action :)
Chris
Jun 29, 2011 | Panasonic SC-HC30 Audio Shelf System
DAB preset is stuck on chanel 1. Machine will not allow DAB to retune or move to another chanel
Have you tried pressing the play mode button to change from preset to station list which will allow you to view all stations available.
Nathan.
Jan 14, 2011 | Panasonic SC-HC30 Audio Shelf System
Retune Panasonic SA-EN38DB DAB radio + ipod dock
Original manual found - note the Model No. is listed as SC-EN38DB i.e. complete system (main unit = SA-EN38DB; speakers = SB-EN38; remote control = N2QAYB000245):
"Press and hold (PLAY MODE) until 2DAB AUTO SCAN' appears. When a frequency is tuned by Auto scanning on this unit, the ensemble corresponding to the frequency is displayed for approximately 2 seconds"
Nov 17, 2009 | Panasonic Electronics - Others
Change speakers on Panasonic SC-HT995W
absolutely ,but remember that theese home theater combo,s are sonically matched so you should find speakers that are rated to the same power handling and frequency response of the one,s you are replacing, if the frequency response is close to what you had that will work fine , if you were to use speakers that were rated for higher output your amplifier will not be able to push the sound of the higher rated speakers and you would not be getting the optimal listening experience , thanks and i hope i helped you ,sincerely Glenn
Mar 02, 2009 | Panasonic SC-HT900 System
I cannot read the manual for panasonic sc-ht07 (English ?)
You can download your user manual here
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
Jan 20, 2009 | Panasonic SC-HT07 System
13 people viewed this question
 Grubhead
Grubhead
