Question about General Electric Profile WPGT9150 Washer
Leak puddle on floor after running
My bottom mounted freezer continues to freeze up and leaks a small puddle on the floor
You have a drain hole behind the rear wall of the freezer compartment. You will need to remove the shelves, screws and clean the hole of ice and gunk. here is a video below.
Leaking Refrigerators Leaking Refrigerators
Appliance 911 Sea Breeze
Aug 02, 2015 | Refrigerators
Whirlpool gold dehumidifier leaks water on floor and we do not use hose just the pan, puddles of water on floor.
check your condensation hose for leak or the pan may have a crack in it or it runs too much for the water to disapate
Oct 23, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a Kenmore refrigerator side-by-side with water/ice in door. Model number 363.9534783 serial number L431 12755. It is now intermitantly leaking water on the floor. A couple of days could go by with...
1. A door open partially will cause a frost build-up then thaw and run down to the floor. Check all doors for proper closure and educate other users.
2. An issue with an unhappy animal is quite common
3. Door switch intermittently causing a light to stay on ora fan to not run
4 Ice build up around ice door chute .
5. Water dripping into ice tray and overflowing. Replace water valve.
Oct 18, 2017 | Kenmore 57029 Side by Side Refrigerator
PUDDLE OF WATER ON FLOOR MAINLY AFTER WASH IS
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 15, 2010 | Dishwashers
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Apr 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water puddling on front passenger floor mat and
are you sure it is water, smell it to ensure it is not antifreeze (smells sickly sweet), if it is antifreeze possibly heater core leak, otherwise check for plugged evaporator drip tube (with a/c of course), could also be leaking body panel (cracked chalking etc). hope this helps
Jan 26, 2010 | 2001 Chevrolet Suburban
Have replaced door gasket and dishwasher still has puddle of water in left corner of floor after running. No visable leaks.
most likely you have too much soap in the unit that is causing sudsing. suds will over run the tub and leak out the corners. try to run the unit with no soap and use the water heat option. after that you should cut back on how much soap you are using. it might be as simple as that.
Jan 03, 2010 | Whirlpool DU960PW Dishwasher
Dehumidifier leaking onto floor.
You should clean off the condensor coils with a vaccum and soft brush. Also, check up inside the area where the condensate drips into the collection reservoir (or goes directly into a hose attachment discharge) to see if something is partially obstructing the water flow and is dripping onto the floor, etc.
You might find that you've got some buildup of dust, dirt, and some other gunk that is mis-directing the water (condesate) that the dehumidifier is drawing out of the air.
Lastly, check the unit to see if it's level, but frankly, I highly doubt that's the issue, based on the 5+ years of good working service for you.
So long as the unit is still running and keeping the humidity in check, (if the above steps don't resolve the issue), I'd continue using it until it finally quits running, but I'd put a plastic boot/shoe mat under it to catch the small puddles of water.
The dehumidifier should draw the small puddles, so it'd be less expensive to get a $4 boot mat than dropping another $240+ for a new unit, as your's seems to be working fine, aside from the occaissional puddle issue.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Dehumidifiers
Wall a/c is leaking water down log wall and puddling on floor.
When you sealed the holes outside, you trapped the water inside. The unit is designed to let the water run to the bottom of the pan and then go out the holes outside. Try unplugging one of them and see if that fixes the problem. Hope this helps.
Jun 24, 2009 | Emerson Heating & Cooling
General Electric Profile WPGT9150 Washer Logo
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
