Ar answers L8r g8r
I think the bottom bolt was cross threaded on ,the bolt was rounded out when i went too loosen,and now im thinking i have too cut ,drill and tap the whole l8r,does that sound right
What bolt? and what is a l8r? Cut drill and tap is not a problem, most bolts when they break, they loose their hold, so they come out easily. Instead of drilling, you might try the old dremel to cut a slot in the head or what's left and turn it like a screw. Hope this helps.
Mar 10, 2010 | 2002 Pontiac Sunfire
Turn the tv on, 1-2sec's l8r it turns off
sounds like the TV has a damaged power supply, most like caused by a bad capacitor on the power board, the capacitor exploded and leaked all the gases which stores electricity, so the power board isn't getting enough flow of electricity for the tv to stay on, very easy fix if you know what to do and have good soldering skills.
May 10, 2009 | 2003 Mitsubishi Outlander
Sharp AR-M201
no. i cant print. its showing red light and user guide attention
Jan 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
Copier toner
Hello sir; the answer is "no" not fit!
Jan 07, 2009 | Sharp AR-M205 Copier
Sharp AR-151
Try this sequence
Press: "Clear", "Exposure Select Key", "Clear", "Exposure Select Key", "26", "Start Key", "39", "Start Key"
there IS another subcode besides E7 try holding the stop or start or clear key you will probably see some different #'s
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Radio Shack Digital Answering Machine Cat #43 3825
No problem, follow the below link for your manual. http://support.radioshack.com/support_phones/doc72/72809.pdf Good Luck L8R
Sep 17, 2007 | Lands Phones
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
