Question about Bosch 24 in. SHV55M03GB Built-In Dishwasher
Dishwasher will not tun on
Lights nothing will not turn on power still connected
Dw60w cata dishwasher has power,turn it on power lamp does not light up, changed lamp still dont light up or work.
Ck to see if dishwasher service switch is in on position . Did the breaker trip. Do you have power to dishwasher ? Is the door lock working ?
Apr 23, 2014 | Cars & Trucks
I have an 1988 FLHTC 85th Anniv. model.
Hi Anonymous, probably a dead battery, put it on a slow charge overnight and ckeck the voltage in the morning. Voltage should be 12.5 to 12.8 volts. Also check battery terminals for clean tight connections. Good luck
Apr 07, 2014 | Harley Davidson FLHT Electra Glide...
Electrical issue
Check the main fuse located near the battery positive wire (red).
Apr 07, 2014 | Motorcycles
Lg LDF6920ST has no power. I went to turn on to run and nothing happens. Does not light up or anything. Was working fine this morning. Now nothing. Checked and made sure the breaker was not blown.
First check the small electrical box at and behind the kick plate below the door. Possible loose connections, usually wire nuts make the connection, turn them clockwise to tighten, check for melted wires at the connection. If all ok test there with a voltage meter at the white and black wires. Should be around 110. If nothing house issue, if power dishwasher power button or eoc issue. You can reset the eoc by disconnecting power for 5 min then reconnect.
Oct 30, 2013 | LG Dishwashers
Power led light on when pressing power it tuns on and goes of right away? power still lit..
I have the same problem, did you figure out what the problem is and solution by any chance? i purchased it recently, it started doing this the night after i left it on for the night. next day everytime i turn on, it turns off in 2 sec. after a month i tried a shot, it started and stayed up for 1 min may be... then same thing again 2 sec. i guess i have to wait for a year to turn it on .
garden led light
May 29, 2012 | Office Equipment & Supplies
Just won't work!!
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
I would also advise to check the door switch as well. make sure the wires are connected to the switch and it is working. replace if found to be faulty.
Check the control as well. if the control is malfunctioning as you stated, this will be the logical solution here. replace the control board.
May 29, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
I have no power on my dishwasher. I ran an extension cord to another outlet that I know has power and still nothing. I don have any led lights or anything. Can you help. GE model # GHDA960K03BB. Thank...
Few components may cause power failure to your Dishwasher.
1. Disconnect your power plug from the socket outlet.
2. Trace the cord to where it connected to your dishwasher.
3. Tight those connectors firmly .
4. Plug back your dishwasher power cord .Start your dishwasher.
If nothing happen, check if control board came with fuse or bimetal. check the continuity of the fuse., You may also check your latch assembly.If no power still change the console or the control board.
Jul 26, 2008 | GE Dishwashers
Dishwahser won't start, start button won't light
I took the door apart, removed the control board, which I had expected to replace. I disconnected the ribbon cable that connects the control panel to control board cleaned the connections and reassembled everything. The dishwasher has been working since.
Jun 16, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Stopped working altogether
Check the door switch, it may have gone bad or maybe isnt connecting with the catch, making it look dead. They wont do anything when the door is open, as you know. Also remove the lower panels to get to the inside of the dishwasher. Check for power where the cord is plugged into the machine. If you have power, unplug it and look at the terminals to the heaater element. They are on the right side, facing down out of the dishwasher tub. Just look inside the dishwasher to see where the heater goes through, then look in the same place underneath, Check the condition of these connections. The timer gets power through the heater element (strange but true) so if the heater is bad or these connections have heated and melted, it will cause a dead dishwasher. if tis just the connectio, pu t a new terminal on it and you should be good to go. Hope this helps
Jun 19, 2007 | Asko D1716 Built-in Dishwasher
Bosch 24 in. SHV55M03GB Built-In Dishwasher Logo
23 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
