Question about Toshiba e-Studio 4540C Multifunction Color Copier
Can I print without borders?
Printing
How to print borderless?
Have a look at settings or paper size, print size etc. There must be a setting you can change to allow for full page printing without a border.
Dec 09, 2015 | Office Equipment & Supplies
Printing 11x14 photos
First use a photo processing programme (like say Photoshop or PS Elements - or if you have not got that (can be expensive) get the free Faststone Image Viewer and size the image to twice the paper size you want, then use the crop tool to select half the image and save that as a file with a name where you can find it again. Do the same with the other half. You will now have two files, each half of the paper size. As they will have small borders, print and trim the borders, so you can then mount side by side to achieve what you want. I would advise to NOT try and print without borders - that can introduce other problems - just accept having to trim the small borders from normal printing.
Apr 09, 2014 | Epson Stylus NX230 Small-in-One USB...
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
Kodak 6850 how do I print 4x6 on 6x8 paper without huge white border... now that you cant buy 4x6 media ?r
the 6'' paper is not the problem at all, you might need to crop the image to 4x6 size before printing since most point and shoot camera will not take the photo 4x6 size but 4+ inches, thus the border. richard
Nov 22, 2010 | Kodak Photo Printer 6850 Thermal
Borderless Printing Doesn't Happen
hi as you have set border less printing in publisher and on printer, have you adjusted the layout guides? on the blank page go to arrange, then to layout guides, adjust the numbers to atleast 0.25 (lowest it will go) and save then try printing, the but remember, hp still has a border due to the print heads position they do not travel over the print area like some printers do, you will always get a small white line no matter what...hope this helps
May 24, 2010 | HP Office Equipment & Supplies
Is it possible to set my printer up to print photos without borders
Yes. Review your Canon photo software. Your model supports borderless printing.
When printing from a "PictBridge" device, you can change the settings in your Canon photo software to have borderless prints by default.
Dec 31, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Can't find program for borderless printing
You need to really defining "Border-less Printing". Are you speaking of printing border-less photos? Or do you mean border-less documents.
Border less photos are usually set up in the printer's driver, providing that the printer's hardware allows this function. Some printers, especially older models, cannot print to the edge of a page by design.
Don
Aug 16, 2009 | Brother MFC 6490CW InkJet Printer
HP C4480 Won't Print Borderless
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Kodak 5100 AiO When printing emails the borders
Read through some of the solutions on here and eventually removed print heads and cleaned them and printing of borders and words is now fine. Still have probs with photos being discoloured .
Apr 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printing problem in Microsoft Word 2003
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
Apr 09, 2009 | Microsoft Word 2003 for PC
Toshiba e-Studio 4540C Multifunction Color Copier Logo
63 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
