Question about Home
What are some illnesses caused by bacteria
School assighnment
I want cure for gastric ulcer
talk with a doctor
ulcers in the stomach are from a bacteria infecting liaisons in the linings and it is treated with an antibiotic
the bacteria is Heliobacter pylori and enters the stomach and live in the digestive tract
they cause sores ( ulcers) and if left untreated can cause stomach cancers
reference --www.webmd.com>digestive -disorders
go google and type in --bacteria causing stomach disorders---and read all about it
fixya site is not a medical forum so consult with a doctor as to the treatment
Jun 26, 2017 | Cure Health & Beauty
Helicobacterpylori,what is it??
What is an H. pylori infection? H. pylori are spiral-shaped bacteria that grow in the digestive tract and have a tendency to attack the stomach lining. H. pylori infections are usually harmless, but they're responsible for the majority of ulcers in the stomach and small intestine.
H. pylori is a common type of bacteria that usually infects the stomach. They may be present in more than half of all people in the world, according to the Mayo Clinic. The "H" in the name is short for Helicobacter. "Helico" means spiral. The bacteria are spiral shaped.
H. pylori normally infect your stomach during childhood. While infections with this strain of bacteria typically don't cause symptoms, they can lead to diseases in some people, including peptic ulcers, and an inflammatory condition inside your stomach known as gastritis.
H. pylori are adapted to live in the harsh, acidic environment of the stomach. These bacteria can change the environment around them and reduce its acidity so they can survive. The shape of H. pylori allows them to penetrate your stomach lining, where they're protected by mucus and your body's immune cells are not able to reach them. The bacteria can interfere with your immune response and ensure that they're not destroyed. This can lead to stomach problems. Causes
What causes H. pylori infections? It's still not known exactly how H. pylori infections spread. The bacteria have coexisted with humans for many thousands of years. The infections are thought to spread from one person's mouth to another. They may also be transferred from poopystuff to the mouth. This can happen when a person does not wash their hands thoroughly after using the bathroom. H. pylori can also spread through contact with contaminated water or food.
The bacteria are believed to cause stomach problems when they penetrate the stomach's mucous lining and generate substances that neutralize stomach acids. This makes the stomach cells more vulnerable to the harsh acids. Stomach acid and H. pylori together irritate the stomach lining and may cause sores or peptic ulcers in your stomach or duodenum, which is the first part of your small intestine.
pylori Infection
Jun 24, 2017 | Miscellaneous
What causes excessive mouth watering?
A watery mouth is caused by an excess of saliva produced by the salivary glands. Normally, the salivary glands constantly produce small amounts of saliva throughout the day to keep the oral cavity moist, keep bacteria in check and assist with digestion; the body reacts by swallowing periodically.
Sometimes the salivary glands produce too much saliva, resulting in difficulty swallowing or speaking, drooling or trouble sleeping. While not typically serious or permanent, excessive production of saliva can cause embarrassment and anxiety. Those suffering from GERD are especially susceptible, as the digestive acids present in the mouth can cause the salivary glands to produce as much as two teaspoons of saliva every minute.
Watery mouth usually goes away on its own. In prolonged or especially severe cases, it may be a symptom of a more serious underlying condition such as a sinus infection or other illness.
Mar 16, 2017 | Miscellaneous
I had phenomia 4 years ago the doctor gave me a prescription for antibiotics they cost about 100 dollars each I need to know what the were
Antibiotics are used to treat bacteria infections. It destroys their cell walls in order to kill them. Thus, treat that particular type of disease.Pneumonia is caused by a type of bacteria known as Streptococcus pneumoniae.
Since pneumonia is caused by a bacteria, antibiotics is needed to destroy the bacteria.
Jun 15, 2016 | Cars & Trucks
Why is the food in the freezer soft?
I would be suspicious that the temperature is not low enough and the food is not completely frozen.
THIS IS A VERY DANGEROUS SITUATION AS THE FOOD COULD EASILY NOW CONTAIN BACTERIA THAT WOULD CAUSE ILLNESS.
I WOULD NOT TRUST THE SAFETY OF ANY OF THE FOOD, AND WOULD NOT CONTINUE TO USE THE FREEZER UNTIL I COULD GET IT COLD ENOUGH.
Aug 15, 2015 | Maytag MFI2569 (249 cu ft) Bottom Freezer...
White vinegar can be used on the outside of a water bed mattress to clean it, can it also be used inside the mattress to keep it bacteria free?
I watched a magic school bus cartoon once where they shrank down and went into a pickle jar. The show mentioned that the friendly bacteria was fighting off the harmful bacteria. Hence it is never bacteria free. I don't see any harm of vinegar being inside except that it is an acid and acids slowly dissolve anything.
Nov 09, 2013 | Plumbing
Can food thermometers protect you against illness?
Food thermometers can certainly reduce the risk of eating undercooked bacteria filled food. Pregnant women, newborns, children, elderly and those with compromised immune systems are all at risk from foodborne illnesses so cooking thermometers can be really helpful.
Feb 14, 2013 | Home
School assighnment , does not want to open- due tommorow URGENT!!!!
Sometimes you can only load office programs up three to fives times before it doesn't install.
Try uninstalling Publisher and reinstall just Publisher into the computer.
Aug 13, 2008 | Microsoft Office XP Professional OEM w/...
Home Logo
385 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
