Question about Panasonic Lumix DMC-LZ20
Battery back up is too less.wht to do? - Panasonic Lumix DMC-LZ20
Color code wiring for 2007 dodge 3500 4x4 tail lights and reverse light
Left
TAIL/STOP/TURN lamp: WHT/DK GRN
TAIL/TURN lamp: WHT/YEL
BACK-UP lamp: WHT/LT GRN
Right
TAIL/STOP/TURN lamp: WHT/YEL
TAIL/TURN lamp: WHT/GRY
Sep 16, 2016 | Dodge Ram 3500 Cars & Trucks
Where is the amp and how do i check it in 98 cadillac
Radio Amplifier
Left hand rear of the passenger compartment, behind the rear seat back.
Check the connections , check power an ground .
Connector Part Information
12110088
24 Way F Micro-Pack 100 Series (GRY)
Pin
Wire Color
Circuit No.
Function
A1
PPL
1952
RH Front Tweeter Output -
A2
LT GRN
1852
RH Front Tweeter Output +
A3
BLK
1856
LH Front Tweeter Output +
A4
YEL
1956
LH Front Tweeter Output -
A5
DK BLU/WHT
346
Rear Shelf Subwoofer Coil 1 Output +
A6
LT GRN/BLK
1794
Rear Shelf Subwoofer Coil 1 Output -
A7
YEL
1860
Center I/P Midrange Output +
A8
LT BLU
1960
Center I/P Midrange Output -
A9
DK GRN
1795
Rear Shelf Subwoofer Coil 2 Output +
A10
LT BLU/BLK
315
Rear Shelf Subwoofer Coil 2 Output -
A11-A12
Not Used
B1
DK GRN/WHT
368
Right CD Changer Input
B2
BLK/WHT
372
CD Changer Common
B3
BRN/WHT
367
Left CD Changer Input
B4
LT GRN
1948
Right Audio Input -
B5
LT GRN/BLK
512
Right Audio Input +
B6
DK GRN
1947
Left Audio Input -
B7
TAN
511
Left Audio Input +
B8
DK BLU/WHT
653
Chime Input/Return
B9
PPL/WHT
652
Chime Input +
B10
Not Used
B11
PPL
1807
Class 2 Serial Data Line
B12
PPL
1807
Radio Amplifier (UX8) C3
showgif.do?image=35456
12064749
2 Way F Metri-Pack 480 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
BLK/WHT
651
Ground
B
RED
1242
Battery Positive Voltage (B+)
Check
Mar 22, 2016 | 1998 Cadillac Seville
Boneheaded move While removing Alternator.
Battery power passes through the 100A MAIN fuse in the main fuse box and is connected to the alternator by a BLK/WHT wire. There is a 50A IG KEY fuse that supplies power to the ignition switch. If you accidentally zapped either the LT GRN/WHT or WHT/BLU wire to the BLK/WHT wire, they connect to the PCM. As for your "oops", we all know better but we've all done something like that
Oct 15, 2012 | 2000 Mazda Protege
My dad's '95 Buick Lesabre Custom does not want to keep the battery charging, I've cleaned all the terminals, checked all the grounds and still no luck. I've replaced the alternator and...
It most likely is a fusible link on the starter,connect a large wire(better to be larger than the one that is on there already)to the back of the alternator and go to the positive side of the battery,or to the starter hot post,where the battery positive cable connects to the starter,this will take care of the problem,no fusible link will be needed.The fusible link really hinders the charging capacity to the battery and running of the engine,cause it carries less amps in the smaller fusible link wire,this will solve the problem most likely.
May 11, 2011 | Buick LeSabre Cars & Trucks
Wht battery and where it is located in minolta 7000 Program Back 70
The Battery in Minolta Maxxum 7000 35mm SLR Camera is NP-400 lithium-ion battery.In the program it is located in the located inside
Aug 28, 2010 | Minolta Maxxum 7000 35mm SLR Camera
Need a stereo wiring on a 98 lumina
Battery + orange
Ignition + yellow
battery- blk/wht
dimmer gry/blk
antenna pink
amp wht/orange
l/f speaker + tan
l/f - gray
r/f + ltgrn
r/f - dkgrn
l/r + brown
l/r - yellow
r/r + dkblue
r/r - ltblue
Dec 19, 2009 | 1998 Chevrolet Lumina
I just bought a li po battery but i have to change the charging plug and my old battery has diffrent colored wires one has blk/yel/blu/red the other has blk/wht/blu/orange
Some company's switch the yel and wht or the red and orange wires so they know it is there product. Just wire it the same as you have now. yel is the wht and red is the orange or reverse.
Nov 27, 2009 | RC 11.1v 1250mah 10c Lipo Battery For Rc...
Logitech Ex110 keeps losing connection
Ok wht you need is batteries (preferably rechargable save the earth etc) There is a slot on the back of the keyboard where i think 2 or 3 batteries can be placed in the keyboard take a gander and tell me what ya got.
Oct 18, 2009 | Logitech Wireless Access Duo Optical...
Color wireing codes for DEH-P730 cd player
red - acc power
yel- battery power
blk - ground
blu - power antenna out
blu/wht - amp remote out
wht - left front +
wht/blk- left front -
gry- right front +
gry/wht- right front -
grn- left rear +
grn/wht- left rear -
prpl- right rear +
prpl/wht- right rear -
Aug 23, 2009 | iLO CA3000V CD Player
Panasonic Lumix DMC-LZ20 Logo
24 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
