Question about ASUS Computers & Internet
Reset button ac unit
Where is the reset button?
    Sergeant:
  • 344 Answers
There should be 2 buttons on the front of most towers on a laptop its the on off one
Posted on Aug 12, 2014
How to reset a mp3 player
Normally these are reset by pulling out the AC from the mains for about 30 seconds and then re-inserting the AC mains. With some models, hold down the power button while re-inserting the AC mains. Some models also have a reset command in their setup menu.
If the unit will not reset this could be a fault with the micro-controller area.
May 04, 2014 | Sony BDP-S300 Blu-Ray Disc Player
Ac unit reset keeps tripping
If it runs in test mode but not during normal, there is a wiring issue.
Sep 07, 2012 | Whirlpool Heating & Cooling
AC unit LWHD 1800R won't turn on & test/reset does not respond.
Reverse the wires in the receptacle ,not the ground,this is most likely the problem the way the circuit is set up in the ac unit.Let me know if this helps.
Jul 05, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
Where is the reset button on the Comfortmaker AC-model number NAC048AKC3? Thank you!
if it is a split system that is permanently installed in your house the reset button will always be near the compressor so that means on the outside unit somewhere, you probably wont need to remove any screws to get to it. but before you press that button and think all is well, why did the reset button trip? answer> because it is a high pressure cut off. your unit probably reached over 350psi on the high side line or possibly even higher. that is not good. you may have a dirty condenser coil (outside) and you can just hose that out with a garden hose (pull the disconnect first). or you may have a rotting out coil if your unit is old or you live less than 5 miles from the ocean. Or you may have a bad condenser (outside) fan motor. check that out. if it overloads again after hitting the reset (which this unit may not even have, not all units have these just the higher end ones) well if it does overload again call a licensed ac guy trust me it will cost you less in the long run.
Oct 09, 2009 | Heating & Cooling
RUUD Acheivers Series AC unit
The reset is two pins on the defrost board. Put a flat scredriver across them to reset the board.
Aug 15, 2009 | Ruud UBHC Air Conditioner
Cannot engage RESET Button on plug to power the 220v AC unit
The reset button is a voltage leak detector it is possible the unit has a short in it or the cord has a short
Apr 28, 2009 | Heating & Cooling
Static
SYSTEM RESET To recover from some fault conditions (refer to the Troubleshooting Section) you may need to perform a system reset. To perform the system reset follow this procedure: 1. Press both the talk button (14) and the mute control (15) button on the headset for 5 seconds. 2. When the talk indicator light (17) on the headset blinks, release both buttons. 3. Press the talk button again. 4. Next reset the base unit by disconnecting the AC power adapter (24) from the AC power adapter jack (7) for 5 seconds, then reconnect. The system reset operation is complete.
Jun 19, 2008 | Plantronics CS50 Wireless Office Headset...
Ac unit not powering / starting up
Did you try to plug a lamp into the same outlet as you have the A/C plugged into? It could be that you have no power at the outlet or the circuit breaker could be off or tripped. Something should run like the fan only position.
May 24, 2008 | Goldstar KG6000R Window Air Conditioner
RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Mar 24, 2008 | Dometic Rooftop RV Air Conditioner
Computers & Internet Logo
27 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
