Question about Exergen Temporal Thermometer
Reading in celcius
Not in fehrenheit
How to change domitec rv air conditioner from Celcius to Fehrenheit
i believe you have to press the up and down arrows in t-stat at same time.
Jun 28, 2014 | Dometic Heating & Cooling
I know its very simple but I cant remember how to switch the ferinheight back to celcius in the display screen above my radio and that.. what are the steps?
read the operators guide, its in the glove box.
if missing ,get one, you really need to have it and read the warnings.
Oct 25, 2013 | Suzuki Cars & Trucks
Instructions for how to use a veridian digital thermometer
how do you change it to read Fehrenheit instead of Celsius?
Feb 12, 2012 | Health & Beauty
The temp reading is in celcius how do i change to fahrenheit?
From Celcius the formula is Deg. C divided by 5 multiply by 9 and plus 32.
From Fahrenheit the formula is Deg F minus 32 divide by 9 multiply by 5.
Feb 23, 2011 | 1996 Buick Park Avenue
I have a instant ear thermometer model number 524972 and it is stuck in celsius, how do i get it back to Fehrenheit
When the unit is off, press and hold the blue start button at the top of the unit. Then while still holding the start button, press and hold the ON/Memory button (you should now have both buttons pressed). The display will power on and you will see the setting toggle from celcius to fahrenheit. Once the setting has changed you can release both buttons. Repeat the entire process in order to toggle the setting back to celcius.
Jan 18, 2011 | Becton Dickinson BD Instant Ear...
I have a honeywell thermostat magic stat/32 model 3200. It reads celis and not farinheit. Just started doing this.
Remove main stat from subbase. On back of main stat there are some screws used for different settings. Screw "C" if for fahrenheit and celcius. Screw in for fahrenheit and out 1 turn for celcius.
Jan 17, 2011 | Honeywell Heating & Cooling
What color antifreeze does a 2003 dodge durango use?
I do not think the color matters, just read the label what temperatures it operates properly as some a green, some blue and some orange, I personally use the orange ELF antifreeze with operating temperatures from -23 Celcius to +50 Celcius
Dec 29, 2010 | 2003 Dodge Durango
I have the instant ear thermometer model number 524972 and it is stuck in celcius, how do I get it back to Fehrenheit
When the unit is off, press and hold the blue start button at the top of the unit. Then while still holding the start button, press and hold the ON/Memory button (you should now have both buttons pressed). The display will power on and you will see the setting toggle from celcius to fahrenheit. Repeat the entire process in order to toggle the setting back to celcius.
Oct 31, 2010 | Becton Dickinson BD Instant Ear...
I have a 2003 kia sorento and my a/c and heater display reads celcius how do i change it to ferenhiet
Push the ambient button and the up/down temp button for 3 seconds. up for celcius down for ferenhiet if I remember correctly
Dec 26, 2009 | 2003 Kia Sorento
I can't change the temp. reading from celcius to regular temp.
Check the manual, you have to hold down Ambiant and the Temp Up button for 5 secs or something.
Jan 15, 2009 | 2002 Hyundai Santa Fe
Exergen Temporal Thermometer Logo
51 people viewed this question
Top Exergen Home Experts
Donni Steen
Tom Chichester
Are you an Exergen Home Expert? Answer questions, earn points and help others
