Question about Vision Fitness X1500 Elliptical Trainer with Simple Console
Knocking Noise on vision fitness x1500 cross trainer
Constant noise coming from left hand arm/leg. Knocking sound very distracting. What is it. How do I fix.
Looking into the engine bay, I have a distinct gurgling w/knocking sound coming from the left end of the engine, constant and loud, aux water pump maybe?
There is only one coolant pump. Front of engine. Noise could be crank bearings or piston wrist pins. Find some that can tell. either way it is an engine rebuild or replace.
Jul 02, 2016 | 2002 Volkswagen Cabrio
Knocking noise
check the sprocket sometimes they are put together with screws and it might be extruding out and rubbing.
Mar 04, 2014 | Yowza Fitness CAPTIVA - Worlds 1st...
Ing sound coming from left handside of xsaara picasso
If the knocking sounds like thudding or something dull is knocking on the car, remove the left front wheel and check the drive shaft boot. It could have been torn and parts of it is hitting the lower arm. If it comes from the engine, check the engine mounts, all 3 of them.
Jan 26, 2014 | 2001 Citroen Xsara Picasso
Knocking noise from front end
bad motor or transmission mount.
Nov 11, 2017 | Saturn Ion Cars & Trucks
Clunking noise precor 5.35
Hello
check for slop in the left and right hand side arms and foot tubes.
I'd tighten every bolt you can find.
GymWorld.net.au
Jan 09, 2014 | Precor EFX 5.35 Premium Series Elliptical...
Kenmore 106.55242400 ice maker knocking noise
most likely you need a new ice maker,one thing that could do this is the white arms that spin around when dumping the ice,sometimes one of the arms bend and jam the ice maker and you'll hear that knocking soundthe arm gets bent,the ice cube gets stuck because the arm can't push it out,,it stops the motor from spinning through it's full cycle and damages it but this is just a guess from something i've seen happen but most likely you need a new ice maker,one other i've seen is the metal arm that you can lift up to shut off the ice maker gets knocked out of the hole it slides into.if you pop off the white cover and get a jumper wire and stick it into the h and t holes you can jump start the ice maker.http://appliantology.org/gallery/image/659-manual-harvest-on-a-whirlpool-modular-ice-maker/
Jan 02, 2014 | Whirlpool Refrigerators
Whats the sound clicks when turning left
Its your axle joint. It has a constant knocking noise which comes only when turning full.
Dec 10, 2013 | Cars & Trucks
What kind of cross-training will help my fencing?
Cardiovascular fitness and leg strength is advised, so anything that enhances these will be beneficial. Cycling, swimming, aerobics, and skating are good examples. Running, sprinting, soccer, basketball can also be helpful, although some athletes dislike the stresses they put on the knees. Racquet sports like tennis, badminton, squash, racquetball, and table tennis are also excellent, and will exercise your weapon arm in addition to your legs. Some fencers maintain that juggling improves reactions, hand-eye coordination, and use of peripheral vision. I can tell you for me the best exercise is swimming and tennis.
Jul 29, 2012 | Sport & Outdoor - Others
Vision Fitness X1500 Elliptical Trainer with Simple Console Logo
61 people viewed this question
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
rattack1511
Level 1 Expert
ray gallant
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
