Question about PfaFF Tiptronic 2040
The thread on the botton of the material is all looped up.
  • 136 Answers
Try carefully rethread top thread
Posted on Jun 18, 2009
Janome one step Despite altering the tension dial the top thread is looping on underside of material and when pressing the reverse button material puckers.I tried adjusting the tension dial from 0-9
Usually, this occurs because the top thread is not fully seated in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Reset your top tension to the midway point and then tweak it.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Jun 07, 2017 | Janome Sewing Machines
Thread bunches up under material
Utter rubbish Connie....look at this comprehensive solution that is why I wrote it !!
to Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Nov 15, 2011 | Sewing Machines
The thread on the top side of my material starts looping after 4-5 stitches. I've tried every number of thread tension, and even on 0 it loops on the right side of the material, not on the back.
Check the tension on your bobbin thread. When you hold it by the thread and let it dangle does it just drop down without any resistance at all? If so then you need to tighten it a bit. If the bobbin thread is too loose it can not pull the top thread down enough thus puts the loops on the top side of the stitch.
Feb 25, 2011 | Brother LS2125i Sewing Machine
The threads under the material being stitched forms loops - the thread can be easily slipped out and the work undone.
top thread tension is too loose try tightening the top thread tension until the loops disappear.
Good Luck!
Chris
glfi.com
Feb 10, 2011 | Sewing Machines
Janome 4400 bought new bobbin holder but still have lots of issues with thread looping while sewing. The repair person says I pull the thread forward after cutting it and undo the proper bobbin threading....
looping the material ( bird nesting) is an indication of incorrect needle thread tension before threading the needle pull the thread and there should be resistance to the pulling
Nov 15, 2017 | Janome MC 4400 Computerized Sewing Machine
I am having a problem with the tension on my Necchi. The botton thread tends to loop every few stitches. I have adjusted the screw on the bobbin case, but it still tends to loop. Sometimes the thread...
check the tension on the top thread
check your needle-roll on flat surface to see if it rolls correctly
you might check the bobbin to see if it's warped-I've gotten some that were warped
Sep 20, 2010 | Necchi 3101 Mechanical Sewing Machine
The wrong loops are on the surface of the material that I've sewn
Loops on the top of the fabric are usually caused by the bobbin thread not in the bobbin case tension correctly, remove the bobbin and reinstall it. You should feel a slight resistance when you pull on the bobbin thread.
May 29, 2010 | Brother CS6000i Computerized Sewing...
Machine is threaded but thread not sewing into material, just holes!
Check bobbin thread....Insert the bobbin thread into the bobbin case in a clockwise direction...pull the thread through the **** on side of bobbin case and slide up into small opening...make sure you pull through about 2 inches of thread to enable upper thread to loop. Good Luck
May 10, 2009 | Sewing Machines
Sewing Machines Logo
223 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
