Question about H.D. Hudson Hudson Trombone Sprayer - 140 Psi
It only spays about 2 feet instead of 20 feet
How to convert 200 cubic ft to square feet
Cubic feet is a measure of volume, while square feet is a measure of area. There is no direct conversion between them.
Imagine two rooms that are 20 feet by 20 feet. One room has a ceiling 8 feet high, the other has a ceiling 10 feet high.
Both rooms are 400 square feet, but the first room is 3200 cubic feet while the second is 4000 cubic feet.
Oct 14, 2016 | Office Equipment & Supplies
How many cubic yards for a 20x12 slan 4 inches thick
Assuming that 20x12 means 20 feet by 12 feet, then you take the three values in feet - 20, 12, and .333 (4 inches is 1/3 foot).
Multiply these three numbers to get the cubic feet:
12 x 20 = 240
240 x .333 = 79.92
Now that you have 79.92 cubic feet, to get cubic yards you divide by 9 since there are 9 cubic feet per cubic yard.
79.92 cu. ft. divided by 9 = 8.88 cubic yards (round up to 9).
Jul 27, 2016 | Building Materials
I need the Linear feet: It measures 24" tall, x 10" thick, x 15 1/2" wide. Can you help?
linear feet is a length measurement as to how long it is --example : a piece of timber 20 feet long is 20 linear feet
the measurements you have provided will give a cubic feet measurements which is a volume measurement. so convert all the dimensions to feet , multiply all together and that will be your volume
May 03, 2016 | Luggage & Travel
How many cubic yards would it take to fill in. 20' x 2' diameter
Hi Paula:
A mathematical logic question.
You need to get all of the measurements in the same units.
- A cubic yard is 1 yard x 1 yard x 1 yard
- equals 3 ft x 3 ft x 3 ft
- equals 27 cubic feet,
so once you have the volume of the pipe in cubic feet, you divide by 27 to get the volume in cubic yards.
- Volume of a cylinder (the pipe) is the cross sectional area X length.
- Area equals Pi x r squared.
- equals 22/7 x 1 x 1
equals 3.14#####
times length (20)
equals 62.857### cubic feet volume
divide by 27 cubic feet
equals 2.328### cubic yards.
- The answer is always the easy part.
- what is important is knowing exactly what the question is, and
- determing what calculations are needed to get the answer.
Wasn't that better than if I'd just said 2 1/3 cubic yards?
Cheers
Jan 05, 2016 | Office Equipment & Supplies
How to convert one foot to cubic feet
To get cubic feet, you multiply the length of each of the three sides.
So:
If something is 1 foot by 1 foot by 1 foot, that's 1x1x1=1 cubic feet
If it's 1 foot x 2 feet x 3 feet, that's 1x2x3=6 cubic feet
and so on...
Shawn
Aug 15, 2014 | Kenmore Refrigerators
How to calculate cubic feet ?
Calculating the cubic feet of a space requires multiplying the area of the bottom times the average height. You get the bottom area by multiplying the length times the width. Remember, to get cubic feet, you need all your measurements in feet to start with.
Here is your formula:
VOLUME (in cubic feet) = Length (in feet) X Width (in feet) X Height (in feet)
If it's a rectangular room you're working with, it is all straightforward. If there are irregular walls, it may be necessary to divide up the room into rectangular sections and then add together their individual volumes. If the ceiling is sloped, you need to use the height that has the same ceiling area above it as below it. Good luck! Truly.
Jul 25, 2014 | Building Materials
I have a Hamilton Beach 0.9 Cubic Feet 900-Watts Digital Microwave Oven and I can not find out how to change the power setting for cooking.
Assuming its the same as my Hamilton Beach, you first enter the cooking time, but don't press start yet, instead press power, then a number button 1 - 9 for the power level 1 for 10%, 2 for 20% etc. THEN press start as normal
Oct 29, 2010 | Microwave Ovens
H.D. Hudson Hudson Trombone Sprayer - 140 Psi Logo
37 people viewed this question
Top H.D. Hudson Garden Experts
Dennis Key
Dennis Key
john h
Are you a H.D. Hudson Garden Expert? Answer questions, earn points and help others
