Question about Command Communications Comswitch 7500 4-Port Phone/Fax Modem/Ans M
Comswitch 7500 keeps ticking
Green light flashing ticking sound
My refrigerator keeps ticking
Blow through the jet and heater gauze to make sure the flame is reaching the end of the thermocouple. If the flame is going out all the time suspect the thermocouple is at fault
Apr 22, 2014 | Dometic Refrigerators
I have a samsung 920n and the power light just keeps flashing green when i switch on and there is an intermittent clicking noise every 2 to 3 seconds.. i replaced all caps (one 470uf was damaged) exce
Are you sure that you used the correct type of capacitors in the repair? They need to be low ESR, High Temp and High ripple current. Capacitors from places like Radio Shack or FRYs will not work because they are only general purpose and the switching power supply can not work right with them installed and they could even damage the electronics on the board. Here is some more information on getting the right capacitors.
http://www.ccl-la.com/blog/index.php/capacitors/
Jun 13, 2012 | Samsung Computers & Internet
Heelooo i have compaq monitor v74 ,624t. when on it give sound tick tick..... smps on and off i need circut dia gram. i am sharma..
circuit diagrams exist at the factory where they were designed. Though I have looked before they cannot be found. I do not believe they exist.
Mar 27, 2010 | Compaq CV 7500 17" CRT Monitor
Display (compaq 7500) is dead and there is a ticking sound from
Check the HOT also check to see if you have B+ voltage line looks like either fbt or output transistor.
Dec 27, 2009 | Compaq CV 7500 17" CRT Monitor
Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
Dec 03, 2008 | Canon LaserCLASS 7500 Plain Paper Fax
I have a vinotemp it stopped cooling no light and keeps making a ticking sound, I tried to unplug it for a while and plug it back and the ticking sound goes back again but still no light no cooling, please...
You can fix this for $5. You can confirm the problem by taking the back off and see of the red and green led on the circuit board are flashing. They will be steady if the board is ok. The fan is usually just rocking too like it is trying to start. The part is a capacitor and is $5, but you will need to be able to remove and solder a part on the circuit board. If you need the part, just let me know.
David
Oct 23, 2008 | VinoTemp VT24-G 24 Bottle Wine Cooler
Modem keep rebooting.
It sounds like you have a bad modem. Have you tried to plug the device into a different power outlet? This will rule out that it's a possible power issue in the outlet.
If no change by trying a different outlet I would replace modem.
Hope this helps.
MO
Jul 12, 2008 | 2wire 2700HG-B Router (2700HGB)
Command Communications Comswitch 7500 4-Port Phone/Fax Modem/Ans M Logo
Top Command Communications Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Command Communications Lands Phone Expert? Answer questions, earn points and help others
