Question about Philips VOIP8411B/37 IP Phone
Help i have philips voip phone that is connected to the linksys router, after we change the password the Voip phone is no longer working what should I do?
  • 4 Answers
Sounds like you simply have to sign out from skype from the phone, change your auto-login password to the new one, then try logging back in again.
Posted on Feb 12, 2008
Hello, I have a Linksys PAP2-VN VoIP adapter from Verizon Voicewing which you know is now defunct. I cannot access the web setup utility because it requires a password that was set up by Verizon and I...
HelloThe Password/user name will provides you by Verizon, try admin:admin
Here is a list of the most prominent VoIP services providers of this type but better service:
1. Vonage 2. Lingo 3. Voip.com 4. BroadVoice 5. Packet8 6. ViaTalk 7. AT&T CallVantage
Hope it helps, if so do rate the solution Good Luck
Dec 28, 2010 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Sep 09, 2009 | Linksys Ultra RangePlus Dual-Band...
Hello,I have connected a linksys voip
Hello dandashi77,
I am using a Panasonic DECT 6.0 Series cordless phone. However, the VIATalk.com VOIP Services uses a LinkSys PAP2 adapter which can work with any type of phone. A Broadband connection is required to use the VIATalk.com VOIP service. Setup is very simple and the instructions areeasy to follow. Just a few simple things to do.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jul 30, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
SPA942 IP Phone d/n work with Linksys WRT54G
You must have a voip router from your voip phone company (vonage,t-mobile). It should not work at all unless you have one of these devices. Hope this helps
May 03, 2009 | Linksys SPA942 IP Phone
Can't access voice tab on WRP400
If your wireless VoIP router was provided by your VoIP provider they will usually lock this option on the router since they have pre-configured the voice settings(sip server, phone number, password, codecs) before they deliver the device to your location. if you have a working internet connection already you can give your VoIP proiver a call so that they can remotely check the voice settings on their end to verify if it's working or not.
Nov 24, 2008 | Linksys Wireless-G WRP200 Router
Connect my phone adapter
You need to register/subscribe to a VOIP provider first like Vonage and the likes. Then you need to register through your VOIP provider the phone ports of your router. ISP is different from VOIP.
Oct 24, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linksys SPA2102 interfearing with winmx/360 sharepro, frequently resetting connection
If your planning to connect the phone adapter behind a router make sure that the following ports are open/forwarded on the router; UDP ports 5060-5061, UDP ports 16384-32767 take note that 5060 and 5051 one are SIP ports and must be assigned to the IP address of that was assigned to by the router to the adapter or the IP that was manually configured on it.
I found a link that could help you check the setting on your linksys phone adapter
http://www.voipvoip.com/linksys-pap2/
Hope this will help you solve your VOiP problem...
Regards,
Sep 11, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Voice_adminpage password?
connect ur pc through hard wired and open web page and type 192.168.15.1 hit enter and hope this is a voip vonage router and
user name : admin lower case
password : admin lower case
and click on administration and under neet that u can see voice and if u want to go through support login u need to contact vendor because the password will change everu 20 minutes and iam sure there is no voice login
rate me solved if its helps thx
Dec 04, 2007 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Philips VOIP8411B/37 IP Phone Logo
158 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
