Question about Kenmore 62802 Electric Dryer
Dryer times out after just a few minutes on both the moisture sensor and timed dry. The timer and temperature sensors have been replaced.
  • 291 Answers
Disconnect your venting and pull dryer out 3 ft. from wall. Test to see if the same problem happens. If it works fine then you have venting problems. Does this have a thermistor? If it does then change it.
Posted on Dec 16, 2009
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
Gas dryer does not dry in "timed Dry" setting
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
My roper dryer works fine, it heats and the timer advances, it just wont shut off at the the end of a timed dry or auto dry. What do you think?
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john_32f4b76dad4781c4
Dec 17, 2014 | Roper Dryers
Dryer won't turn off
Timer motor is shot. Remove a wire from it and check continuity. If the timer does advance in timed dry i suggest you yank out the dryness board and clean the contacts. The dryness board is a small board with a capacitor mounted on it. The capacitor is connected to the drying sensor bars inside. As the wet clothes rub the sensor bars the capacitor gets discharged. When the capacitor gets fully charged (because the clothes are dry) then the timer motor gets power. If the contacts on the board are corroded the motor won't advance. If it advanced and shut down after only a few minutes that is dirty sensor bars (no moisture being sensed). MORE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 23, 2013 | KitchenAid KEHS01P Electric Dryer
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Dryer won't shut off. Heats fine. Timer advances on air dry only. Vent is not clogged. Can't find moisture sensor replacement part.
https://www.repairclinic.com/Shop-For-Parts/a8b104d87061/Model-CYE2000AYW-Magic-Chef-Dryer-Parts
The dryer requires cycling of the heat to advance thhe timer on auto dry cycle. see ,link provided parts and repair guidance. Always remove from power supply first.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Sep 30, 2017 | Magic Chef CYE2000 Electric Commercial...
Moisture Sensor Location
It could be the sensor. However, check the exhaust vent for restrictions first. you can test the moisture sensor Damp Dry Test 1. Set the following Timer- DAMP DRY Fabric Care/Temperature switch- COTTON HIGH Wrinkle Guard switch- OFF Signal switch- LOUD Door- must be closed 2. Press the PUSH TO START switch. After approximately 16 seconds, the Timer will start to advance to the OFF position, and the ?End of Cycle? signal will sound. If one or more of these functions do not occur, proceed to the Factory Test. Factory Test The Factory Test allows factory/service personnel to test and verify all inputs to the Even Heat control. The basic operation of this test is to notify the operator with an audible beep every time the status of an input to the control changes state. Activating the Test Mode 1. Set the following configuration: Door- must be open Fabric Care/Temperature switch- AIR FLUFF Signal switch- LOUD Timer- TIMED DRY OR AUTO MOISTURE SESING PLUS selection 2. Turn the Wrinkle Guard switch from OFF to ON three times within a five second period. A single beep will sound to indicate that the factory test mode is activated. NOTE: If any of these initial conditions are not satisfied, the control will not enter the test mode. Test Mode Functionality When the control is in the Factory Test mode, every input change of state will result in a beep (with the exception of the Signal switch). This includes: Door switch Moisture Sensor (short/open Sensor will result in a beep) NOTE: A moistened finger or damp cloth may also be used. Fabric Care/ Temperature switch Wrinkle Guard switch Push to Start (PTS) switch (with the door switch closed) Timer (any cam input change will result in a beep) NOTE: Timer will advance during test. If any of the inputs do not result in a beep, proceed to the following component tests If the dryer shuts off too soon when set to the AUTO MOISTURE SENSING PLUS cycle, check the following: -HARNESS/CONNECTION -MOISTURE SENSOR -THERMISTOR -EVEN HEAT CONTROL Procedure: 1. Test the Moisture Sensor by following the procedure outlined in ?Factory Test?, beginning on page 3. If the Moisture sensor fails the ?Factory Test? (does not produce a beep sound), check the Moisture Sensor. a. If there is continuity to Ground for Yellow/Red (Y/R) wire with no load, look for a short in the Sensor or Y/R wire. Verify harness connections both at the Sensor and the Even Heat control. b. If the Sensor and Y/R wire are good, replace the Even Heat control. 2. If Factory Test passed, verify thermistor by performing test procedures outlined in ?Thermistor Test? 3. If problem persists after replacing Moisture Sensor and thermistor
Aug 27, 2007 | Kenmore 62972 Electric Dryer
Kenmore 62802 Electric Dryer Logo
89 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
