Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Show me wiring on the control panel
I need to see the wiring under the top control
  • 283 Answers
It's located on a sheet in a plastic envelope taped to the inside of the lower cabinet
Posted on Apr 01, 2014
How to replace pto wire on Kubota L2800
No need to remove any panels. the bottom end attaches to a lever on the right hand side of the transmission. Can be reached from under the tractor. There was an update on the control cable which changes the angle of the bracket on the top end so the wire does not bend and break so quickly. check with you dealer to see if yours qualifies.
Jan 01, 2017 | Kubota Garden
What's your problem?code F35 is coming up
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned. This problem could be caused by a failed analog pressure sensor, a problem with the air tube connection between the analog pressure sensor and the bottom of the washer tub or a failed central control unit.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
A loose wiring connection or a broken wire harness could be causing this problem. You can remove the top panel of the washer by taking out the screws at the very back of the top panel. Pull the panel back slightly and then lift it up and off of the washer. Check the wire harness connected to the analog pressure sensor. Also check the air tube connected to this component. If these connections are okay, check the analog pressure sensor connection on the central control unit. THE IMAGE BELOW (click the link for zoom) shows the location of the central control unit on a similar model of washer and also provides a wiring diagram. The analog pressure sensor harness plugs into the central control unit on the PR8 connector. Make sure that this connection is secure. Look for damage to the wire harness.
If this dont solve it, I suggest replace the analog pressure sensor (shown in THIS LINK). Additionally, keep in mind that if your device is less than a year old, then this component is under warranty and should be replaced by a dealer technician.
Oct 13, 2011 | Kenmore Elite 45986 Front Load Washer
Need kenmore electric dryer model 110.66662500 wiring diagram. will not heat
Should find the wiring diagram under or in behind the control panel accessed by removing the 2 screws holding the panel down either in the front lower or rear lower end caps . If you can't see any screw heads there may be removable covers on the end caps from top to bottom . On some newer models you can insert a putty knife under the end caps on the front and depress a clip on either side and the whole control panel lifts and lays back. Before any of that check your fuses at the panel 2-- 30 amp
Nov 04, 2010 | Kenmore Dryers
Smart drive MW059 with fault code 3,5,7,8 wont fill starts and stops filling about 6 times then above fault code shown
Hi Todd,Just read your posting.The fault you have is called OUT OF BALANCE SWITCH FAULT.Now the switch is located under the control module which in turn is located under the top panel.To access the control module remove the 2 screws at the back of the machine up top.Once the screws are removed lift the top panel away from the machine gently as the display wiring is still attached.You will now see the gray control module.You should also see a screw holding the control module to the frame,remove it and look under the gray board to the right.You should see a switch with 2 wires attached .Have you or can you borrow an electrical test meter to test the switch for conductivity on the terminals with the wires attached?If there is any corrosion on the switch terminals or the little button does not click positivity when pushed I think the switch will be faulty.You must have conductivity between the 2 wires.Make sure the power is off at the wall before you remove the top panel.If the switch is good then the fault could be you control module.Hope this helps and please reply on how you got on or for further help.Looking forward to your reply.
Sep 12, 2010 | Washing Machines
GE washer Model S3600DOWN will not turn off water. overflows WHY?
suspect water level control they call it a pressure switch
there is a quarter inch line that runs from tub to pressure switch that line can sometimes plug requiring line be removed from pressure switch and cleared
http://www.repairclinic.com/Washing-Machine-Top-Load-GE-Style-Appliance-Diagram
this web page shows a breakdown of commom top load ge washing machine level control is located in top panel
before opening top panel unplug washer from wall
if clearing line does not work level control will probably need to be replaced suggest take picture or draw out
where three wires are hooked before removing part or
change 1 wire at a time to avoid mixing up wiring
Dec 12, 2009 | GE Washing Machines
Remove the top
Hi, The top does not come off seperate. It comes off when you remove the cabinet. Why do you need to remove the top and I can help you further.
Vic
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't start. shows CE on the display
That is a communication error between the control and the motor board.
Could be a corrosive buildup on the ribbon connectors and/or a bad wire or loose wire.
You can unplug the machine and trace all wires to look for a pinched or loose wire.
Unplug and clean all wire connections.
If that does not work it will be a bad motor controller.
Mar 04, 2009 | Kenmore 24032\24036 Top Load Washer
Need schematic to remove top
No schematic needed.
Unplug washer
on the bottom of the control panel remove two screws, one on each side.
control panel flips up and over self.
Now on each side under control panel are gold colored clips to remove cabinet from back panel. use a screw driver and release clips,
unplug any wires going to top panel from rear panel that make hold back cabinet,
Cabinet pivots on locator pins on lower front of base. Now with cabinet removed, top can be removed from cabinet shell
Jul 15, 2008 | Whirlpool Washing Machines
Whirlpool oven that does not broil
Nabril, looks like you have a thermal fuse in the broil circuit. Take your meter and on the control board go to connector P2-2, should be a blue wire. Pull the connector off and see if you have continuity from the blue wire to the red wire on the terminal block (where the cord connects) power off, wires off. If you don't have continuity, it's probably that fuse. If you do, the only other thing I would think it could be would be the relay itself. The schematic does not show the placement of this fuse. It could be on the back panel or under the main top. Check out the pic. Part number..3196548 Catriver..post back.
Apr 21, 2007 | Whirlpool RF369LXPQ Electric Kitchen Range
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
