No picture sound ok rca 46la45rq
Black screen, powers on fine, sound ok on all channels
    Genius:
  • 1,039 Answers
Sounds like backlight is dead. Shine flashlight on screen. Can you see video slightly. Replace inverter or some sets have inverter as part of power board. If led set replace led driver board. Also that may be part of power board.
Posted on May 13, 2014
SOURCE: No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Posted on Sep 28, 2008
  • 1779 Answers
SOURCE: Picture but no sound on two cable channels. All
Make sure under the Audio Menu that you have SAP turned OFF
Posted on Jul 09, 2009
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
  • 19 Answers
SOURCE: Polaroid 19" TV TLA-01911C has no picture. Powers up, see logo
To add to this solution above - I had the capacitor replacement and there was still an issue. Turns out the solder connection to the lamps themselves was very very poor causing an electrical arc (the scratching noises people are hearing) - then the inverter shuts the lamps down as it should. Fix lights!
Posted on Dec 10, 2009
milkburp
  • 416 Answers
SOURCE: no sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Posted on Mar 26, 2010
Tv screen has gone black but still have sound when you shut the tv off and turn it back on the screen comes up but it flashes and goes black again
Hi Bob, The link below is a YouTube video showing how to fix a RCA television(DIFFERENT MODEL) NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
RCA 46LA45RQ tv repair No picture no power troubleshooting
May 01, 2016 | RCA L46WD250 46 in. LCD HDTV
Rca 46la45rq has backlight and power but no sound or picture replaced main and inverter boards
Was this the original problem before replacing the main board?
Maybe you have to set the new main board from maintenance menu. Sound and image comes from the main board, so i believe it has to be something about it...
good luck
Aug 31, 2014 | RCA 46 46LA45RQ LCD TV
Rca tv powers up has backlight no sound or picture replaced main board and inverter
I would check the input board for correct power supply input
check the blue 15pf 6kv caps near the output from the PSU to the inverter.
RCA 46LA45RQ tv turns on with sound and after 1 second the picture goes out. The blue power light stays on and the audio, but no picture.
Back-light inverter board fault. Replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 17, 2014 | RCA 46 46LA45RQ LCD TV
Black screen, no picture just audio
Check and replace its main power supply regulator board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 18, 2014 | RCA 46 46LA45RQ LCD TV
Black screen, Audio Fine
Check and replace the back-light inverter board. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
TV has sound but no picture.
Most likely the inverter board if the screen is completely dark (black) But if its a very darkt Blue then its the Tcon most likely. You can get either board from www.tvrepairworld.com
Mar 07, 2013 | RCA 46 46LA45RQ LCD TV
46 rca model 46la45rq comes on for just a second then the screen goes black and it only plays sound! what needs to be replaced
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. Do you see a faint picture?
Jan 14, 2013 | RCA 46 46LA45RQ LCD TV
Rca 46la45rq no picture after loud pop
That could be several items such as power supply or main board, or Inverter . You can find out which board by contacting the people over at
www.tvrepairworld.com they will help you determine which board is most likely causing the issue.
Aug 04, 2012 | RCA 46 46LA45RQ LCD TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
