Question about Sony Audio Players & Recorders
No sound through sony ss-mb215 speaker
No sound
Output wattage of sony speaker system model ss-cfx250
Passive speakers don't have an output wattage rating, that would be applied to the amplifier :-) The INPUT wattage rating of these speakers is 5 watts RMS per speaker.
Jul 14, 2014 | Sony Audio Players & Recorders
No sound from Russound ss-4 after connecting to BACK surround speaker connections on the 2807.
Check the speaker setup configuration in the setup menu. Many times the surround back speaker terminals can be assigned to something else like zone 2. They may just be turned off.
Dec 27, 2012 | Denon AVR-2807 Receiver
How do I disassemble Sony SS-RG440 Speakers to fix a rattle?
If your Sony speakers are in sealed cabinets, the only way to get access inside is through the front by removing the grille and the speakers..BUT before removing the speakers check whether the speaker(s) themselves are the source of the rattle
Dec 26, 2012 | Audio Players & Recorders
Need a woofer for sony ss-mf315
have you tried on amazon,ebay or you could go directly to sony's website and possibly order your 6.3 inch subwoofer
Dec 23, 2012 | Sony SS-MF315 Speaker
Can you tell me if a receiver Sony 7.1 works with speakers ss-mf515 and What happen because I use the higher volume and the speaker sound low?\r\nWhat kind of receiver works with the speakers I mencioned...
Since you don't name the receiver we have no idea of its audio power or compatibility with 'standard' 8-ohm speakers.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-SS-MF515-Speakers-manual/id/956ci160/t/2/
Any normal standardized NOT-all-in-one-hi-fi-in-a-box amplifier will work with these speakers.
Apr 05, 2011 | Sony SS-MF515 Speaker
I have bought a Sony Home theatre with total 6 speakers (including woofer, rear speakers (2), Front speakers with stand(2) and onr central speaker. But the centre speaker is not responding during TV,...
That would all be a function of your HTS, not necessarily the speakers.
Get a handle on how IT works, maybe find the manual and perform setup to verify the speakers work at proper levels.
I imagine it has several Digital Sound Processing modes that can create multi-speaker sound from any source.
http://www.retrevo.com/support/Sony-SS-CN550H-Speakers-manual/id/752ci570/t/2/
Feb 14, 2011 | Sony SS-CN550H Center Speaker
NO SOUND FROM TV THROUGH THE SOUND SYSTEM SPEAKERS
All you need to do is follow the following directions on your TV and you will be on your way listening to your great Philips TV on your great Sony Surround Sound. You do not need to buy any other cords or anything else. Its just a setting on your TV that needs to be adjusted.
By the way, I have a Sony Home Thearte System DAV-HDX275 and I've had it for almost 8 months and its sounds good with my TV and Movies. The speakers are very cheap and it doesn't give you the sound you expect. So I came accross some Boston Accustics CR65's that are not sold anymore but they did run around $700 a peice. I am upgrading the Reciever very soon to a better qualtiy Reciever. This Surround Sound System is great for a starter Surround Sound System.
  1. Press MENU on the remote control and select TV settings >
  2. Press up or down to highlight a sound setting and press right to select the setting.
  3. Press up or down to adjust the setting, and press OK to confirm the change.
  4. Press Menu to exit.
You want to pick Incredible Surround, but if that does not work try them all. The Incredible Surround should do the trick because that switches it from the TV Speakers to the Surround Sound.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Have a Great One!
Mar 13, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
101 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
