Question about Cub Cadet 9 in. 26 cc Gas 4-Cycle Cultivator GC145
How to replace pullcord on cub cadet gc145
Pullcord broke i need to replace it how do i do it
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
  • 142 Answers
SOURCE: cub cadet repair manual
partstree.com may have then or call the manufacture
Posted on Sep 23, 2009
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
Bolt broke off of adapter and blade. I replaced bolt and it broke again. So i replaced the bolt and adapter and now making a loud knocking sound this is on my cub cadet walk behind sc500z
Hi Diana:
I'd suggest that you pull the spark plug lead so it does not accidently start, and then try this.
Place the mower at a height where you can easily see under it. I use the tailgate of my pickup trucl.
If you put the handle inside the bed of the truck you can put a weight on the handle so the deck is tipped up. With the spark plug disconnected (or even removed) rotate the blade. Chances are that the knocking sound will be from the blade hitting the deck. It is possible that the bolts keep breaking because the blade is not seating properly.
I'm guessing that once you can see under the mower you will find the problem.
Aug 11, 2016 | Cub Cadet Garden
I have a cub cadet bc280 2cycle weedeater the pull string pulls but it want go back in need help please
un screw recoil cover and remove be careful because if spring is broke can cause it to pop out unexpectedly and spring is sharp check rope if off track use screw driver to reinsert and should wind back if rope broken will need to replace if spring or coiler damaged also need replacement
Aug 10, 2016 | Cub Cadet Garden
Almost new GC145-started fine last time. this time it looks like no gas is getting into the primer bulb. add gas there, it starts and then dies.checked the hoses and they aren't clogged. Any ideas? Thanks!
You can use programs like "Driver Tuner" to find out if an old or wrong driver is installed. This software can automatically find and download correct drivers.
Disclaimer: Not associated with software vender but have used this software to fix driver issues on couple of computers.
Nov 03, 2013 | Cub Cadet 9 in. 26 cc Gas 4-Cycle...
How to replace pto clutch on cub cadet LT1042
before you replace it check the wires on the old on mine broke one inch from the clutch but you only need to remove the center bolt then it pulls off but when you but it back make sure its locked into the part that holds it from turning
May 09, 2012 | Cub Cadet Garden
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Broken pullcord
before you rethread it you must spin housing counter clockwise till you feel tension (if you let it go you have to restart ) then tread it
May 09, 2010 | Cub Cadet Lawn Mower Idler Pulley Replaces...
Cub Cadet 9 in. 26 cc Gas 4-Cycle Cultivator GC145 Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
