Question about Exercise & Fitness
T960 treadmill and hill position
Cannot put in hill position
User manual for Todo t960 vacuum cleaner
Try Googling (todo)(t960)(manual) without parens.
Mar 22, 2018 | Vacuums
Hi my power first t960 treadmill stops working. it turn's on. startup beeps are ok. display turn's on and showing regular digits. but non of keys working and consul dos not response to any key. thanks
Check the cable from console to motor control board. It would be a detachable connector on both ends. Try removing and reconnecting it. Sometime such problems can occur because of the bad contacts of connectors.Please remember to remove the power before attempting any service inside treadmill.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Exercise & Fitness
How to dismantle t960 power first treadmill for packing and moving
you must take out the power first 2) follow the steps in your owner manual, or download from www.fitness.manualsonline.com +
www.retrevo.com
God bless you
Jul 18, 2013 | Exercise & Fitness
Treadmill
Try to RUN the software calibration for troubleshooting.
However test the elevation motor, Lube THE MOTOR : shaft +gear+adjust the small POT for increase performance. see the diagram attached.
Feb 04, 2013 | Life Fitness Lifestride 9000 HR...
Vision Fitness T960 treadmill error code E4 I was going to recalabrat hit start could hear machine turn off
please proceed according and fix it. See the diagram for troubleshooting and see my personal TIPS for motor help.
"E04": Incline motor wrong, check if the VR of the incline motor connects well or replug it. The
mark of the DC motor and control board should be matched connected. Sometimes you also test the wires from motor and restart the treadmill
Jan 08, 2013 | Exercise & Fitness
How do you unfold the treadmill
there is a release pedal under the treadmill, press down and slowing release the treadmill
Jun 03, 2012 | Tunturi T30 Treadmill
My Power First T960 stopped whilst I was using it and come up with an E1 error. I have lost my users guide so I don't know what this means. Help please!!!
Dear Sir:
I will help you inmediately, do not go in panic:
1) Check is voltage is o.k 115VAC, measure with a VOM(Voltimeter)
2)Try again, if is working. If donot check the c. breaker or fuse.
3) Is everything is o.k the faulty is VSD(Variable Speed Drive) the give the ERROR I.
4) That means the VSD is defective, try to put some special liquid for to clean Pot or contact, and check again.
5) If not you must return the PCB, to the factory indicating the Code ERROR for to fix easy.
Thank you in advance , blessing , sincerely.
E.CUADRA
MANAGUA, NICARAGUA C.A.
Sep 13, 2011 | TEKK Exercise & Fitness
The machine just goes into auto calibrating on the screen and beeps constantly. does not stop auto calibrating Just seems unable to cope with any programs to do with hill climbs
power off, put in the key, press and hold down the 'stop' button and 'incline up' buttons, power on holding down the buttons for a few seconds - message clears
Feb 17, 2011 | Tunturi T60 Folding Treadmill
Lites on control board read ( L 5 ) when machine is turned on.
the e1 symbol is an engineering error code for an electronics malfunction (actually is senses the motor not turning and giving an error. The most likely cause is the motor control board
www.twincityrepair.com
Mar 02, 2009 | Landice L7 LTd Pro Sports Trainer...
Exercise & Fitness Logo
27 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
