Question about Nakamichi Car Audio & Video
Steering wheel control
How it works
4 Suggested Answers
SOURCE: Steering Wheel Control
I installed a body lift and now none of my steering wheel controls dont work any ideas
Posted on Nov 01, 2009
alicantecoli
  • 22326 Answers
SOURCE: steering wheel audio controls dont work when steering wheel is straight
you wll have to remove the steering wheel to find the problem iam afraid ,its called a serpent coil or whatever and this is playing up ,make sure ignition is off nd remove the airbag to get to the steering controls but whatever you do remove the airbag but do not unplug it or the airbag light will stay on
Posted on Mar 28, 2012
Testimonial: "thank you helped heaps "
emissionwiz
  • 79865 Answers
SOURCE: controls on steering wheel not working
Duplicate question.
Posted on Oct 15, 2012
2002 monte carlo steering wheel and cruise control wiring diagram
Is the air bag light lit on the instrument cluster ? Clock spring inside top of steering column , under steering wheel .
How Clockspring Works
Apr 27, 2018 | 2002 Chevrolet Monte Carlo
MY LOW BEAM LIGHTS, BREAK LIGHTS AND RADIO SOUND CONTROL ON STEERING WHEEL, ALL STOPPED WOKING
Steering wheel radio controls and horn not working - Jeep Wrangler ...
www.wranglerforum.com/.../steering-wheel-radio-controls-and-horn-not...
Sep 22, 2014 - 12 posts - ‎6 authors
... 2Dr sport and my step/reset buttons, radio control and horn all stopped working. ... Also the lights behind the step/reset and cruise control went out, but the ... Soundslike a bad clock spring ribbon cable in the steering wheel. steering wheel buttons not working
Jun 14, 2012
Steering wheel audio controls
Mar 5, 2011
More results from www.wranglerforum.com
Nov 23, 2015 | Cars & Trucks
Horn and steering wheel controls not working.
    images for 2004 Suzuki Forenza no controls on
    Suzuki Steering Wheels and Horns ' eBay
    www.ebay.com/sch/Suzuki-Steering-Wheels-and-Horns/.../i.html
    eBayFind great deals on eBay for Suzuki Steering Wheels and Horns in Steering ... 2004Suzuki Aerio Grey and Black Steering Wheel with Airbag OEM 2003 ... 04 05 06 07 08SUZUKI FORENZA- Steering Column, Black with Key, NO AIRBAG ... 2006 Suzuki Aerio Gray Leather Steering Wheel with Controls OEM 05 06 07 Nice.
Sep 25, 2015 | 2004 Suzuki Forenza
Citroen xantia steering wheel audio controls not working
it sounds as thogh the radio isnt the oe one and is not paired the remote is controled by the unit it may be a broken wire
Dec 04, 2012 | Citroen Xantia Cars & Trucks
Steering wheel audio controls dont work when steering wheel is straight
Mar 28, 2012 | Cars & Trucks
Ok i need to know how to assemble the steering wheel
Steering Wheel Removal & Installation Special Service Tools (SST) Required:
  • J1859-A Steering Wheel Puller
  • J42578 Steering Wheel Puller Legs
To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Place the ignition into the OFF position.
  3. Perform the SIR System Disabling procedure.
  4. Remove the inflator module
  5. Scribe an alignment mark onto the steering wheel hub in line with the mark on the steering shaft.
  6. Loosen the steering wheel nut.
  7. Position the steering wheel nut flush with the end of the steering column shaft.
  8. Loosen the steering wheel using the J1859-A SST.
  9. Remove or disconnect the following:
    • The steering wheel controls electrical connector (if equipped)
    • The horn switch lead from the steering hub
    • The steering wheel nut
    • The steering wheel from the steering shaft
    • The steering wheel controls and the steering wheel controls harness from the steering wheel (if equipped)
To Install:
  1. Install or connect the following:
    • The steering wheel controls and the steering wheel controls harness to the steering wheel (if equipped)
    • The SIR connector properly routed through the steering wheel
    • The mark on the steering wheel with the mark on the steering shaft
    • The steering wheel CAUTION
      The fastener is prevailing torque type and may only be reused if the fastener and its counterpart are clean and free from rust and the fastener develops 27 inch lbs. (3 Nm) of torque or drag against its counterpart prior to the fastener seating. If the fastener does not meet these criteria it must be replaced.
      1. Torque to: 33 ft. lbs. (45 Nm)
    • The horn switch lead to the steering hub
    • The inflator module
    • Enable the SIR system.
  2. Ensure that the steering Wheel controls operate properly (if equipped).
  3. Ensure proper horn operation.
Jul 03, 2010 | 1997 Chevrolet Venture
The controls on the steering wheel stopped working and the radio doesnt work either
Replace the clock spring under steering wheel, if applicable to your vehicle
May 06, 2010 | 1995 Buick Riviera
Buttons on steering wheel do not work
have your mechanic check you STEERING WHEEL control module its the unit the control the function on the steering that communicate with veh ecm
Aug 07, 2009 | 2000 Ford Windstar
May 07, 2009 | 2005 Nissan Altima
STEERING WHEEL DOESNT WORK
Find the controller setting within the Game as there is a few settings for wheels. Find the setting that suits your wheel configuation and set it. Should be go to go.
Apr 20, 2008 | Logitech DRIVING FORCE FEEDBACK STEERING...
Car Audio & Video Logo
24 people viewed this question
Top Nakamichi Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Jaime Hernandez
Mohamed Ismail
Mohamed Ismail
Are you a Nakamichi Car Audio and Video Expert? Answer questions, earn points and help others
