Question about Toshiba Computers & Internet
L40m 18z no charging light
Works on batt but not on ac or does not run on just ac
3 Suggested Answers
RescueTechLA
  • 2653 Answers
SOURCE: I have a HP NC 6120 laptop.I have the batt in and
It's probably a bad battery BUT I've noticed this problem pretty often from this model. I would check HP's site for a bios upgrade and I'd also check your warranty status because they just updated they're list of computers that they're extending the warranty on that have the same problem.
Posted on Feb 20, 2009
jhoeldorz
  • 169 Answers
SOURCE: acer 9410 will not run off AC adaptor or charge
Have your Adaptor/Converter checked by a licensed technician. It would be good if it is still under warranty but if not I recommend you bring it for servicing.
Posted on Jan 25, 2010
My battery died and put the charger on it but now the radio wont turn on and the lights and controls for the ac don't work?
Some cars..the module is affectd if batt ran low..below 12.6v they can be ruind. Test batt for holdn a charge. Same w alternator. Also the main cable from batt to alt cud b worn causing low flow
Jun 30, 2015 | 1994 Oldsmobile 88
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Oct 12, 2009 | Dell Latitude D600 Notebook
Dell inspiron 1300 does not see the battery
remove battery check if laptop works fine with ac adapter, if not then download the latest bios version first if fails then replace ac adapter. If laptop works fine with ac adapter. but cannot work with battery alone, download the latest bios then charge the battery for 6 hrs. if still batt not charging then replace batt. but as you mentioned you already replaced the batt and your still getting the same issue. replace motherboard.
Sep 24, 2009 | Dell Inspiron 1300 Notebook
Battery won't charge
Check if you could run it on AC without the battery. If yes, you battery should be faulty or worse dead. If it is within warranty, get it replaced
Jun 24, 2009 | Acer Aspire One PC Notebook
IPaq rx3115 working like PC not Pocket PC, need to plugin always
You need to purchase a new removable battery for your RX
The removable batts usually only last about a year (like cell phone batteries).
Although it is showing 100% charge, the battery is not storing enough power to run the ipaq
The rx series uses 2 batteries, one is the removable one u can see/access when u remove the back cover. The other batt is a small round batt which stores the basic info for your system (so you don't lose your data when u swap out the removable battery).
This small (backup) batt is similar to the cmos battery on a laptop or pc.
You cannot easily replace this, as the unit needs to be disassembled to access this batt.
If you are tech-y (and brave), the replacement button batteries are sold on ebay for $9-12
Normally, if your removable batt is bad, you could still use your unit plugged in, and could
remove from AC power without losing data. Not the case if your replaceable batt is exhausted.
When both batteries are bad, you lose everything when u remove unit from AC power.
My workaround without having to disassemble unit:
Purchase and fully charge new removable batt (They have huge capacity ones available for like $15 - better than the original !).
Load up all your programs & settings the way you like.
Perform full backup to SD card (& also on PC via active sync - to be safe)
Now the only time you should lose your data (like hard reset) is if you allow the battery
to completely drain, in which case you can restore your backup.
If you purchase 2 removable batts, you can easily swapout without losing data if you
use the usb charge cable & leave ipaq plugged in while you change battery
Hope this helps
Jun 01, 2009 | HP iPAQ RX3115 Pocket PC
I have a HP NC 6120 laptop.I have the batt in and the PS plugged in.All that happens is the Charge Light Blinks yellow 6 times then green 1 time,repeats.At the sametime the power light comes on for 6...
Remove the battery and then press the power button for 45 sec then refix the battery and check that the machine is turning on or not?
If the laptop is not working on AC alone then this is the issue with the converter which is there on the motherboard.
Feb 19, 2009 | Toshiba (K000006610) for Satellite P25...
Battery problems Tc 1100
When the Batt is inserted and you are on AC power do you have a lit charge light? It's the one in the center of the three at the lower right when you are in landscape mode.
If your batt is at "end of mission" (**** up) then it's ability to hold and take a charge may be very limited. Calibrating the batt might help. You will need the toaster style charger.
If this is the issue, then the charge light may only stay on for a few seconds at a time when you first attach AC power, so be watching.
I could recommend a new batt (e-bay) if thats your only trouble. Nothing lasts forever. I'm in Missouri and will calibrate your batt if you want to mark it and ship it. Let me know.
B
May 05, 2008 | Compaq tc1100 Tablet PC
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
16 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
