Question about Building Materials
Chamberlain troubleshooting Just installed a Chamberlain PD752D 3/4hp. The first day everything worked. The second day I tried using the light via the control pad light button to no avail. The light will come on when the door is opened or closed with the control pad or the remotes, but the control pad button does not turn the lights on nor off for that matter. The wires look to be still in their respected holes; just not sure what the problem would be except a bad control pad? Any help would be greatly appreciated. Thank you in advance, Chad cbriggle@me.com
    New Friend:
  • 130 Answers
It's rare but I've had new wall switch have flaws. Call chamberlain and they'll send you a new one.
Posted on May 07, 2014
lobsterman72
  • 91 Answers
SOURCE: Door will only close when held down
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Posted on Jun 27, 2008
  • 11 Answers
SOURCE: Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Posted on Jun 24, 2008
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
  • 6 Answers
SOURCE: Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Posted on Dec 07, 2008
  • 3197 Answers
SOURCE: chamberlain master reset
There isn't a reset.
Posted on May 07, 2009
Check to see if sensors (eye) on sides of door are lined up, they need to be looking directly at each other. If that doesn't work change sensors, simple, install, hook up 2 wires per sensor, wire with line to same wire, blank wire to same blank wire and align so sensors see each other.
Jul 29, 2014 | Sears Craftsman LiftMaster Chamberlain...
Will a chamberlain belt drive work with genie safety sensors?
no, chamberlain openers require chamberlain, liftmaster, or craftsman safety eyes
Sep 10, 2017 | Chamberlain 1/2-HP Whisper Drive Belt...
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the...
Try cleaning the door tracks and rollers as if they are sticking the motor will reverse as a safety function. Use WD40 and wipe clean then apply some spray grease.
Feb 28, 2011 | Vacuums
We have installed a chamberlain wireless keyless entry. The problem is that when our neighbors house uses their keyless entry our garage door opens without us using our code. We have checked this seveal...
We have a Chamberlain Whisper Drive Plus. The keyless entry stopped working, suddenly. I have changed the battery, not the problem. I cannot get it to work, and cannot get it to reprogram. The keypad lights up when buttons are pressed, but when I press "Enter" the whole keypad flashes for about 30 seconds and then just goes dark.
May 10, 2010 | Universal Garage Wireless Keyless Entry...
Changed code on the wireless chamberlain security key pad
Does it work from wall button? Hit learn button for 10 seconds. Hit again for 1 second and code keypad.Opener lights should blink 2x. Hit learn again for a second and hit button on a remote (Any button you chose). Again, lights should blink. Now should work. Repeat for any other remotes.
Jul 24, 2009 | Chamberlain 950CB Remote Control
Chamberlain garage door opener unit-is it compatible with craftsman keypad?
Hello,Linda well this is your lucky day ,I have installed garage door openers for sears for 10 years and i can tell you that craftsman,chamberlain ,and liftmaster are all the same machine and manufactured under the liftmaster name , if you buy it from home depot it will be a chamberlain ,if you buy it at sears ,it will be a craftsman, and if you go to commercial building supplier it will be a liftmaster! now getting that out of the way even though they are all compatible ,there is one thing that stands in their way and that,s time ,For example if your chamberlain machine is 5 years old and you went to sears last week ,the chances of the frequency being the same are not good , most likely you have the wireless keypad , one way to test the sears keypad against the chamberlain machine is to locate the smart button on your machine ,this button allows for programming of remotes and keypads , to test and see exactly what im talking about take your remote and locate the smart button ,if you have three buttons on the remote press one of the buttons that are not being used on the remote ,above the smart button their will be a blinking light ,if you press your remote button you will notice the light go from a blink to a rapid flash , This is telling you that you are sending a signal for programming to the machine , well the keypad is exactly the same all you have to do is push the enter button on the keypad and have someone watch for the rapid blinking light ,if they are compatible the light will blink rapidly on the machine so all you have to do now is have someone press the smart button once on the machine your indicator light will now be a solid light you will have approx 60 seconds then to put a 4 digit code in the keypad and then press and hold down the enter button on the keypad , at this point you will notice the lightbulbs on the chamberlain machine to shut off and come back on this is to tell you that the machine accepted the code , after thats been done you can use your keypad , you can also find the owners manual to the chamberlain and follow the same instructions to programming the remote , they are identical in programing , if your keypad is not the same frequency you can also tell by looking at the frequency code on the backside of the keypad and also the chamberlain unit usually where the light bulb is will be its code
Oct 01, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Belt Noise for Chamberlain HD600 1/2 HP Whisper Drive Garage Door Opener
You could always use "Belt Ease" from an Auto Parts store. It's made for squeeky belts.
-Lonnie
Jul 29, 2008 | Electrical Supplies
Building Materials Logo
98 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
