Question about Briggs & Stratton Heavy Machinery
I have a brush master chipper was working but has been standing for 6months now wont work took the plugs off and tried on another machine the plugs sparking.. but doesnt spark on the chipper is it the coil that is broken and needs replacing cheers
  • 3 Answers
Look at the magnita the round **** under the coil you make just have to sand it with a fine sand paper and maybe the under side of the coil
Posted on Jun 18, 2009
My troy built chipper shredder vacuum wont start. It has fresh gas, checked the spark plug and blew out the air filter. Any ideas?
If you have left it standing since last season without draining the old gas then its likely there is old gas residue left as a white crud in the carb. This has blocked one or both jets. If you undo the float bowl and its inside then get the carb cleaned out. You will need an airline.
Nov 04, 2014 | Heavy Machinery
Need parts for Lescha Zak 1800 Chipper/shredder
I have a used lescha zak 1800 chipper. It does not have the stand. I have the motor with the on/off switch and most of the chipper housing. IThe motor runs strong. Reply at asm3davis@yahoo.com.
Sep 02, 2012 | Yard Machines Electric Chipper/Shredder
K45ss kitchenaid stand mixer, i took out the brushes and it wont work n=know when I put them back
jrichards - I hate it when that happens! It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the armature. The concave contact face should be resting completely on the armature. If you've turned it 90 degrees too much, it wont' seat properly. I hope this helps... Howard, Burke, VA
Nov 03, 2009 | KitchenAid Food Mixers
The impeller does not rotate.
Sounds like you probably have a large piece jamming the impeller. Look for an inspection cover somewhere on the outside of it. remove the cover and try to turn the impeller backward with a pry bar of some sort to free it up. DISCONNECT THE SPARK PLUG BEFORE BEGINNING!!
Jun 27, 2009 | Heavy Machinery
MTD yardman chipper wont start get spark need manual
I am successful too at using the starting fluid in the carb or directly into the clinder. That is how I start my MTD 5.5hp chipper. My problem is I have to hold down the primer bulb to keep it running. If not, the engine will stall.
May 12, 2009 | Troy Bilt Walk Behind...
DONT WORK
Hi. Before you get too far, call kitchenaid parts to find out if they still have parts for your mixer. They no longer show a parts list for the KSM90 so your mixer may end up in the trash.
Go to mendingshed.com and select the Kitchenaid products button then select Kitchenaid mixer parts. Near the top of the page locate the button for the free kitchenaid service manual. Download the manual and read about the disassembly and reassembly of your mixer.
This manual does not cover your mixer but is a usefull tool for working on any mixer. Good luck with it.
If this solution has assisted you, please rate it. ricardok45
Apr 18, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
New MacKissic chipper, wont start
it sounds like it is jammed up, take off the plug wire and look inside discharge chute for any debris.
Apr 04, 2009 | Heavy Machinery
Dyson DC7 full Kit, with one belt does not get suction to head.
Not absolutely sure about this, so your feedback will be very welcome.
What follows applies to the DC14, which I think is similar in this respect:
Stand behind the machine, holding the handle at a 45 degree angle. Locate and remove the airway inspection valve (bottom of handle, right side). Where the valve plugs in there is a square plastic moulding that should slide up and down. Snap that square plastic piece up towards the ceiling. After it snaps into place, the machine should stand upright.
Good luck, and please let me know how you get on!
Mar 21, 2009 | Dyson DC07 All Floors Bagless Upright...
Craftsman Chipper-Shredder Model No. 247.775870
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Nov 02, 2008 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Heavy Machinery Logo
716 people viewed this question
Top Briggs & Stratton Heavy Machinery Experts
NOEL
NOEL
Matt Olenzek
Matt Olenzek
Bill Boyd
Are you a Briggs & Stratton Heavy Machinery Expert? Answer questions, earn points and help others
