Question about Fellowes P-12C 12-Sheet CrossCut Paper Shredder
Will not work
Lights are on but will not start
I have a Buick Regal 98 car that want say anything when starting, and the head lights, radio, horn and windows not working.
No radio, no lights, no start = dead battery. Even with key off, lights should come on if battery isn't dead
Jul 02, 2016 | 1998 Buick Regal
My 2004 dodge neon will not start head lights and radio work no dash lights.
Start from scratch, check all the fuses. Have someone with a little knowledge check all the wiring harness multi pin plugs. As some things are working I get the impression a harness plug either in the engine bay or under the dash is not fully engaged.
Feb 22, 2015 | 2004 Dodge Neon
2001 Chev Malibu. Turn key on to start car, won't start. No warning lights on no lights on gauge panel. Radio works, dome light work.
check the ground leg to your engine.. it runs off the neg. battery terminal. will connect to frame and engine.. pull it off, wire brush it put it back.. you radio will work, 'cause it draws much less current, and is grounded in dash.
Jan 11, 2013 | 2001 Chevrolet Malibu
I have a 2003 gr. prix GTP.. my fuel gauge started acting weird(works/does'nt work) then dash lights started doing the same and now headlights have stopped working.daytime lights work but if i tu
Have your battery tested or first clean the terminals and cables. Check the ground cables, not just the one on the battery but frm engine to body etc etc.
Sep 11, 2017 | 1995 Pontiac Grand Prix
After jump starting trunk latch,sunroof,door locks and map lights won't work
when jump starting volvos turn the lights on this will stop the power surge from blowing fuses or relays that have stopped all your bits from working
Jul 31, 2012 | 2001 Volvo S60
The lights inside my car work, until I try to start the car, then nothing works and won't start.
If the lights come back on when you release the key, I would check for a dead cell in the battery and poor connections at the battery and starter.
Jul 13, 2012 | 1992 Honda Accord
Key turns on but no click or start, Radio works lights work but key turns hard. No solinoid click and doesn't start.
check battery and connections first starting requires 300 plus amps lights about 50 so lights work but not enough to start try jump and if starts take to parts store and have then test battery
Jul 06, 2009 | 1998 Dodge Durango
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Fellowes P-12C 12-Sheet CrossCut Paper Shredder Logo
61 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
