Question about AMT Datasouth ACCEL-6350 Matrix Printer
Forms are printing too high up
Too high to start printing
Legal paper printing for canon 1210laser
For printing the Legal Size in cannon LBP-1210, follow the instruction:
Go to Start - Printers and Faxes - go to File menu - click Server properties - Create a new form (give name for ex : Khan Legal) then go to width : 8.50 inch. and Height : 14.00 inch - and then give specifications for LEFT - 0.20 RIGHT - 0.20 TOP - 0.20 BOTTOM - 0.20 - and then save form - go to Canon printer icon - set as default printer - go to properties - select forms - click Form 2 - change form - (Khan Legal) what ever you mentioned name - then apply - click OK - print a test page -
Hope this works.Cheers.
Jul 02, 2011 | Computers & Internet
How do I align the top of form position & for adjusting printing position on my pre-printed form?
Make sure continuous forms are in the printer.
Press Alt and then press Setup to enter Setup Mode.The
printer prints out the Main Menu.
To select a function, press the buttons listed on the printout.
To save the setting and leave Setup Mode, press Start/Stop
until out of the menu.
Jul 13, 2010 | Lexmark 2380 Plus Matrix Printer
Prints on two cards
You can modify the position in the menu.
The start position can be prgrammed in the personal settings.
Moving the paperwon't change anything because the printer will always check the top of feed
Sep 03, 2009 | Datamax I-4208 Thermal Label Printer
Lexmark T632 printing about 1/32" too high on form.
Hi, the only way to solve your problem is to change the layout of your form on your system. Good luck, Gerrit Jan
Jul 29, 2009 | Lexmark T632 Laser Printer
Windows XP, pre-printed P.O. forms. Iif I line it up in the same spot to print it never starts on the same line, always to high or to low. The info is being entered into an EXCEL page.
Your Okidat print emulates othe printers. Print out configuration and see what your printer is emulating and load the driver for that printer and all should work ok. Fought same problem for weeks, until I Loaded driver for printer it is emulating.
Mar 05, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 3320
There is no easy way. You need to adjust starting position for every form. There is fine feed function and Top Of Form setting procedure, so you can adjust the minimum space between top of porm and first printed string (user's guide explains in details how to do it). But after that you need to decide whether you manually set the start position by rotating the knob or play with your application to adjust margins etc.
Dec 24, 2008 | OKI MICROLINE 3320 Matrix Printer
How to print on custom paper
Worked it out in the end -
1. In XP classic view, Right-click on Start, Settings, Printers & Faxes
2. In the Printers & Faxes window, click on File, Server Properties
3. With the Forms tab selected, check the Create a New Form box
4. Enter a name for the new form in the Form name: field
5. Enter values for the paper size and margins
6. Click the Save Form button
That's it - the new custom paper size should now appear in your print dialogs. hth.
Sep 23, 2008 | HP LaserJet 2550L Printer
I keep getting the print alignment form every time I start the ptinter. I don't want it except when I change cartridges. How can I stop the unwanted printings of this form.???
check your settings. it might be set up to do a print page at start up. check the settings to make sure it is not set uo this way.
Aug 15, 2008 | HP Computers & Internet
Printing 'Form information: No form stored' non stop
rchamorro,
Sometimes, resetting the printer to the factory defaults solves some of the problems. For troublehooting and to overwrite all stored parameters, send the ^default command.
Mar 14, 2008 | Zebra LP 2844 Thermal Printer
Tally Voucher printing
see just go start setting and printer in printer right click go to server properties in that you will get option of creating form choose new form and give the sige of voucher so whenever you printing voucher select this paper size. bye
May 29, 2007 | Epson LX-300 Matrix Printer
AMT Datasouth ACCEL-6350 Matrix Printer Logo
32 people viewed this question
Top AMT Office Equipment & Supplies Experts
k24674
Are you an AMT Office Equipment and Supply Expert? Answer questions, earn points and help others
