Philips Model ID 20pf5120/28
Philips LCD tv 20 inch using rabit ears antenna no cable do I go to factory reset
Have no Picture or sound do I use the orginalfactory settings?
    Sergeant:
    Champion:
  • 223 Answers
Recently, cable has gone digital. You might not be able to get a signal anymore with rabbit ears. They suggest buying a converter box. You can always try restoring factory settings...
Posted on Jun 15, 2009
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
CANT TUNE IN
You must connect an Antenna to use the AutoTune. A set of rabit-ears is sufficient for most areas: RE: the Digital (Free) TV singals are using the old UHF/VHF frequencies - so any antenna designed for Broadcast TV should work. Connect your antenna to the ANT/Cable connection then re-run the Auto-Tune again.
Jan 10, 2015 | Televison & Video
Gpx 32" tv/dvd player, no picture only sound
Do you have a cable provider that gives you TV service ? Or do you use a regular ("rabbit ears") antenna ?
Dec 14, 2014 | GPX 32" 720p LCD HDTV/DVD Combo
A GPX model tvwb534 connecte to an indoor rabit antenna doesn't work?
You either may have the set on Cable setting or the signal is too weak for the set to pick up the channels---indoor antennas have a very limited range and many channels have ended on air broadcasts completely
Mar 24, 2012 | Televison & Video
I have new Philips LCD 47"tv and on the bottom
HI:
You may of turned on the Philips Easylink which is for connecting Easylink-compliant devices that are connected through HDMI connectors can be controlled by a single remote.
You can restore the default picture and sound settings of your TV.
1. Press MENU
2. Select SETUP> Installation>Then Factory settings.
3. Select Reset to start resetting
5. Press OK.
6. Press MENU to exit.
Jan 24, 2011 | Philips 42PFL5332D 42 in. LCD Television
No tv channels with Philips 42FD9935/17
If you are using a Cable Box, then select the Cable Box option in the TV. If you have connected the Antenna directly to the TV, then select the Antenna option in the TV under Menu options. Try performing the Auto program.......If using a Cable Box, then no need to perform the Auto program. If the issue persists, try resetting the TV to the factory settings and check if it helps.
Jul 25, 2010 | Philips FTR-9964 Tuner/Receiver for Plasma
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
Picture freees
What you are describing is either a fluctuation in the signal strength for a particular channel/channels or a momentary lapse of the actual broadcast signal. The reason why the picture freezes instead of just getting some static in it is because the signal is digital rather than analog.
Dec 30, 2008 | Insignia 37" LCD Flat-Panel HDTV
Nhens convertor box www.dsconter.com
Posting regarding the NHENS converter in January 2009. Bought it at Radio Shaft and it works -- feeding an old Panasonic b/w TV on channel 3. Live within 25 miles of the Empire State Building and the converter has managed to pick up and lock up on all NYC signals but channel 13. Also brings in channel 41 (licenced to NJ) and its subchannels plus the nearby channel 58 and its NJN-2 subchannel. Antenna is an amplified indoor rabbit ears with a loop also from Radio Shaft perched atop a kitchen cupboard on the 2nd floor of our house. Apparently, NHENS managed to correct the above referenced problems.
Aug 29, 2008 | Philips Magnavox 20MT133S 20" TV
Sanyo dvw 5000 setup
If you rabit ears have a ribbon cable you will need a coax adaptor. Radio Shack carries them. If you cant find them, you might have to get a set of rabit ears that has coax wires. The antenna will plug into the cable in of the DVR. You take the coax output and plug that into the tv using a coax wire.
Aug 04, 2008 | Sanyo DVW-5000 DVD Player/VCR
Televison & Video Logo
282 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
