Question about Crock Pots & Slow Cookers
The presure cooker dos not seal tight for cooking stea is coming out of the sides
  • 3 Answers
The lid is not on evenly or the nuts are not tight enough on the cooker. If this is a used cooker be sure the lid and the pot belong to each other. They could be a mis-match.
Posted on Jun 16, 2009
How do i brown meat in defy presure cooker. Can I brown the meat before cooking
saute in a skillet on top of stove first then put in pressure cooker
Apr 04, 2018 | Crock Pots & Slow Cookers
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
Using Farberware 7-1 pressure cooker food is taking long time to cook. Lid is sealed and cooks under pressure. How to set for high pressure cooking and other pressure setttings?
This question was posted in the wrong category but it would be advisable to Google (Farberware)(7-1)(manual) without parens to get instructions for use.
Jan 15, 2017 | Crock Pots & Slow Cookers
Should the lid be a tight fit or loose
Most crock pots are made of porous ceramic and is relatively brittle. It is glazed on all sides (except the bottom usually), to make it hold liquids without absorption. The lids, usually glass or thermoplastic, sit of top, but do not usually fit tightly as this could crack the crock. Also, it is not a pressure cooker, so you want excess steam to vent. The lid just keeps the heat inside and allows condensation to drip back into the crock, reducing the speed at which the fluids cook off, thus the term slow cooker.
Nov 06, 2015 | Hamilton Beach Crock Pots & Slow Cookers
Steam release valve is not very tight....very loose. how do you install it?
I posted the same question, as I was very nervous about the loose fitting steam release valve. I thought for sure it was defective. I have never used a pressure cooker before and I think most people are nervous the first time. I finally called customer service and was told this is how it is supposed to be. It's supposed to be loose, and the lid won't fit tightly. Everything works out fine when you start the cooker. The valve tightens up and the lid fits securely. Keep in mind also that it takes quite some time for the cook cycle to begin. When it took so long to start the actual cooking, I thought yes, I was right, this one is defective. But I cooked a perfect turkey breast and am continuing on to make turkey soup. I hope I have helped, as there doesn't seem to be anybody who wants to share their knowledge with us newbies!
Feb 08, 2011 | Wolfgang Puck 5-Quart Electronic Pressure...
Do you lock the lid while cooking?
make sure u DO NOT lock the clips while cooking, its not a pressure cooker. if you lock the lid the heat and pressure from whatever you are cooking causes an air-tight seal and the lid will shatter or the ceramic pot it self will crack...
Nov 29, 2010 | Hamilton Beach Set & Forget Stay or Go...
Presure weight plastic is off
You can remove the plastic cover from the vent valve and it will work fine. If you remove the plastic cap, you will need to manually tilt the valve with a utensil to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Feb 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Steam comes out through rubber seal, it takes longer cooking, where can I purchase a seal.
try contacting the maker voia phone or computer,remember to include make and model number
Dec 16, 2009 | Faberware FPC800V 8-Quart
Lid not a tight or smooth seal
Hi, I have a Durabrand Slow Cooker and before that I had a Rosemary Conley one, both had loose fitting lids but this did not affect the cooking etc. I think that is the way they are meant to be. Use a non slip mat too as this may help, mine never vibrated even on high. Maybe you should get someone to look at it for you.
Jan 22, 2008 | Rival 38501 Smart Pot 5-Quart
Crock Pots & Slow Cookers Logo
88 people viewed this question
Top Crock Pots & Slow Cookers Experts
tsalagi152
Irene Tulloch
Marvin
Marvin
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
