Question about Keurig B60 Coffee Maker
Suddenly the water wont come thru when theres a kcup in it
Water passes thru without the kcup but not with the kcup
    New Friend:
  • 63 Answers
Check the needles have not been damaged (top and bottom) if they are jot properly puncturing the kcup the water may be being blocked
Posted on May 21, 2014
2 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: Model B70, with no Kcup
The plastic cup that you drop the k-cup into is removable for cleaning. It's not obvious how it pops out, but it does with just a little pressure. In the bottom of that part is a hollow needle that punctures the bottom of the k-cup. This needle is clogged. A toothpick works pretty well, or maybe a pipe-cleaner if you have one. good luck, Al K
Posted on Feb 03, 2011
Helpline
Sounds like a cleaning problem. Mix 1/2 vinegar and 1/2 water pout into machine and brew,WITHOUT K CUP! Do 5-6 x's and then brew plain water to rinse vinegar out. Do this several times. Should be ready to go.
Mar 31, 2014 | Keurig Coffee Makers & Espresso Machines
Keurig drinks taste bad like plastic
try running viniger threw it then flush it out
Aug 29, 2012 | Cars & Trucks
I have a one cup at a time Keurig. I measure the water and pour in then Kcup coffee. I shut the covers and press brew. The coffee maker starts to heat the water but then will not pump the water through...
I have one too. Had the same problem and needed a new clean Kcup. The oil residue build up wasn't allowing the coffee to pass through. Some models also have internal filters. Bed Bath Beyond has all the replacement parts and lists the units by Model on the part. Hope this helps.
Sep 05, 2011 | Vacuums
Water will not flow through k cup but will flow into mug without kcup
Check that the lower puncture pin is not clogged. Pass a fine wire through it.
--W/D--
Jan 18, 2011 | Keurig Elite B40 Coffee Maker
When trying to make coffee, very little water passes through the kcup, most of the water "recycles back into the tank
when trying to make coffee, very little water passes through the kcup, most of the water "recycles back into the tank
Jan 02, 2011 | Keurig B60 Coffee Maker
Keurig B60. Brand New used maybe 4 Kcups. Now it won't fill a full cup setting. Maybe 1/4 cup. You reset, get a little more to run through. At this rate going to be a long time for a full cup. took...
if water does go thru it...try white vinagar/water mixture about 1/2 cup vinagar to full tank water..
run cycles until empty...NO Kcups..then run full tank of clean water.....
Dec 18, 2010 | Keurig B60 Coffee Maker
The keurig spits water into the water resevore and does not make a cup without first turning off the machine and turning it back on several times
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Sep 23, 2010 | Keurig Special Edition B60 Coffee Maker
My keurig coffee maker will not draw water into the tank and shuts off after a minute.i hear the pump but it wont draw water
Sep 15, 2010 | Keurig B50 Coffee Maker
My keurig wont brew
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Sep 03, 2009 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
43 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
