Question about Dewalt Garden
No pressure coming out of powerwasher
Everything seems to be running fine but there is no pressure while running
2 Suggested Answers
  • 42623 Answers
SOURCE: Why doesnt my powerwasher pump out water
check for a blocked jet in the end of the wand ( squashed hoses or blocked hose to the wand)
the blocked jet has the same affect as not pulling the trigger and the pressure regulator bypasses the water back into the pump
Posted on Sep 08, 2015
Testimonial: "I have disconnected the wand hose! I get a dribble at the most out of the pump!"
Sep 08, 2015 | Annovi Reverberi RMV2.5G27D Pressure...
Powerwasher pw1800u
The water pump is pretty much shot! Did you crank the pressure washer without the water being on? Most times you see this when this occurs.
Jul 13, 2013 | Garden
Bissel powerwash 1690 does not dispence water
Hey George, not having spray when you're ready to clean can be frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1052&cid=ccsocial
Jan 21, 2013 | Bissell Carpet Cleaner Powerbrush Deep...
No pressure
you will have to try the following start up purge up onece with just water then start the powerwasher if that does'nt give u pressure ther is gaskets inside the pumping sometimes 4 to 8 of them these might be to wore down to hold pressure if u can locate the pump and desemable it run it to ur local dealer tell u need new gaskets put into it
Apr 09, 2010 | Porter Cable PCH3200 Commercial Pressure...
Excel powerwasher with B/S motor. Will start and
Is your air filter dirty? If so replace it. If it is still doing the same thing try this:
Turn off the fuel valve, or drain the gas tank, then place a rag under the bowl to catch the gas that will run out (the bowl is under the carburetor). Loosen the "nut" that holds the bowl on, and after the gas has stopped draining remove the nut and bowl. Blow out with compressed air, if available. Put the bowl back on and try to start it. If it still will not run off choke, the carburetor probably needs a good soaking or to be replaced.
Jan 25, 2010 | Briggs & Stratton Pressure Washer...
Help! i have a pacific hydrostar 65078. Engine runs fine. Pump pressure is good with the hose off. the stream shoots across my driveway. But when i connect the hose(sears 3/8 25'' i loose all pressure.
You have to have a clogged hose gun. Try blowing it out with air. Also, Harbor Freight sells the Pacific-Hydrostar and you can buy a 2 year full warranty for around $70 bucks. A small price to pay if you use your powerwasher on a frequent basis. If anything goes wrong, regardless of what the cause, they simply replace the washer.Hope this helps.
Nov 20, 2009 | Garden
No water coming out from powerwasher. Motor is running
check the filter at the inlet water pipe connection, a long nosed pliers may help to remove.
Aug 16, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Honda 2750i Powerwasher
I had the same problem 3 years old, maybe used 10 times - removed the air filter and the washer started fine. The air filter looked fine - I have not tried to replace it or figure out the root cause. I was just happy to get it running again :)
Aug 09, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
