Question about 2008-2012 Chevy Silverado 1500 4WD Front Wheel Bearing & Hub Assembly
Humming noise coming from temp sensor above diver door
Senor is humming
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Unsure if you have a sensor in that location, more likely a cell phone speaker in behind the headlining
Posted on Oct 07, 2014
When we shut the fridge door a loud continuous humming noise comes from the fridge. This seems to be activated by the door light switch at the top. Thank you
There are 2 possibilities I can think of for the hum. When you activate that door switch it activates 2 fans and the compressor. There is one fan located on the compressor and one located in the vent system in the fridge. The second fan is used to circulate cool air evenly through the fridge. I would recommend holding your finger on the door switch and listen carefully whether the noise is coming from inside the back of the fridge or from the lower bottom. Lower bottom could indicate compressor cooling fan or compressor. They would need to be inspected. If it sounds more like the other fan mentioned above it would again need to be inspected. The compressor cooling fans can get stuck or become noisy due to bearing failure. The vent fan can get stuck or noisy but also in some cases if the defrost circuit is not working can chock up with ice and create a buzzing noise as the fan blades strike the ice.
Jan 13, 2017 | Refrigerators
98 chev silverado..........stops running when the air temp is 90* and above. acts like it just runs out of gas. set for 15 min and runs fine.
if you can see the data of pcm the coolant senor could be out of range.or the map sensor itself located on intake manifold defect when getting hot
Aug 29, 2013 | GMC Cars & Trucks
My cooling fan will not come on at all. I've changed the temp sensor and if I wire the fan direct, it works. Otherwise, if I'm in traffic on a hot day, it will peg the temp gauge. Could it just be the...
Try changing the coolant temp senor...Its usually by the thermostat by the housing....Start up your car and let it run for a bit.....then unplug the electric plug from the sensor....If you unplug it and the fan comes on....that sensor is your problem. Or it could be your coolant fan relay.
Nov 06, 2010 | 1995 Chevrolet Cavalier
Choke coming on even in summer, is this right
it seems that your coolant temp senor is what causing this to happen it's natural inless it revs really high and stays above 1100 rpm's after the engine heats up.
Jun 09, 2009 | 2004 Hyundai Santa Fe
The oven wont heat up above 50
HI, this is not a serious issue here. you will need to test the resistance of the oven temp senors. it seems to be defective. also, check the wiring harness from the oven temp sensor to the control. make sure the wiring harness is in good condition. replace the oven temp sensor if found to be defective.
May 30, 2009 | Hotpoint SY36 Style Line Stainless Steel...
Fault code F3, then F2
Well here's the details about those codes:
F2 :-
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
F3:-
Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor
Apr 04, 2008 | GE JGBP28 Gas Kitchen Range
2008-2012 Chevy Silverado 1500 4WD Front Wheel Bearing & Hub Assembly Logo
65 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
