Question about Packard Bell oneTwo L A6524uk All In One Touchscreen PC
Pb onetwo s3270
Too bright
4yr - PB Onetwo L5710 All-in-one Desktop PC, press ON button, light appears in the button as the pc will try to start but after 5 to 8 seconds, the light will go away and the computer will turn off.
check all your connections, and give it a good clean could be a build up of dust as many dont realize this can make your computer malfunction
Jul 04, 2015 | Computers & Internet
Packard Bell OneTwo M3700 PC boots up but no display
most of the time on older monitors you can set the refresh rate in safe mode and that will, most of the time, resolve the problem otherwise time to purchase a newer monitor.
Jun 26, 2015 | Packard Bell Computers & Internet
Packard bell s3270
You can have a much as 8GB (2x4GB) RAM in the device. Here is a video that explains how to access the RAM. Good luck!
How to upgrade memory in Packard Bell OneTwo Computer
Apr 17, 2014 | Acer Computers & Internet
One two touch will not boot, power switch just flashes
Beep codes are nice but you have to know who makes the BIOS to use them. Check the RAM and see if it is loose.
Feb 05, 2014 | Packard Bell Computers & Internet
Onetwo board type
That is an all in one computer. So, no those boards are not standard. You should be able to find a replacement board if you are needing it on ebay, or directly through Packard Bell.
And atx and matx are referring to motherboard size. (micro)atx boards are smaller, usually less feature rich, and more densely packed, but they are usually cheaper than the larger, roomier, usually more feature rich atx boards.
Jul 29, 2013 | Packard Bell Computers & Internet
Bought a Packard Bell Onetwo L5851 yesterday. Unable to switch it on....Blank screen with a few lights below,thats it . Nothing responding.
I have a similar problem with a Packard Bell OneTwo S PG4G1TU01 : when switching it on, it work a few minutes and suddenly shutdown, as a brutal power down. But the green light at the bottom still working. I have changed the extern power supply and now it work fine... The new power supply is a 90W model, not a 65W like the original one. Maybe it can help ?
Dec 28, 2010 | Computers & Internet
How to connect a dvd player to lcd tv
Your DVD player's output is Composite Video (the yellow connector) plus stereo audio (the red and white connectors, for right and left audio)
The inputs on your TV are for Component Video, which splits the video signal into three cables (Y for brightness, Pb and Pr for blue and red, respectively)
Check your TV to see if it has a composite input (single yellow connector, labeled "video" or "composite")
And be sure to let me know if this helps!
Oct 24, 2009 | Televison & Video
Packard Bell oneTwo L A6524uk  All In One Touchscreen PC Logo
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tony
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
