None of the keys has an effect,possible flash drive expiration
There is a limit to how many
keystrokes a computer can retain ahead of what it is doing in real time. When
the number of keystrokes entered reaches that limit, no further keystrokes can
be entered and the warning tones indicate this fact to the user.
Try reestarting the computer to clear the
error.
If the error persists after restarting, then probably
the spring loaded mechanism under the key in question has become stuck in the
depressed position. If so, try to gently lever the key up with the flat blade
of a table knife, avoiding, if possible, unclipping the key itself.
If this is not possible, you might
have to deliberately unclip the key to see if the mechanism under it is
damaged. If it is not or it can be unstuck, then carefully re-clip the key.
If none of the above are possible,
it may be necessary to replace the keyboard.
I
hope this helps.
If
this Answer goes some way towards helping to resolve your Query, Problem or
Fault, please take the time to Rate it.
Doing
so helps Solution Providers, like me, better understand the needs and the point
of view of Askers, like you, and guides us in exploring the best ways to
provide the most comprehensive, useful and high quality Responses and Solutions
we can.
If you
need further help, please do not hesitate to post another Question or add a
Comment to this Question.
Thanks for using FixYa.
