1394 board mimaki - E102161C fix? - Office Equipment & Supplies
Mimaki jv33 error 205
dear sir, we have Mimaki JV33-160 and when the power on i see Error 205 please help me
Jul 07, 2012 | Office Equipment & Supplies
Which driver is best for Gigabyte GA-7vt600 1394 Motherboard? I installed realtek AC-97 but it didnt work
Realtek AC 97 is the only driver for this board, did you install the 64 bit driver rather then the 32 bit driver?
Jan 01, 2011 | Gigabyte GA-7VT600 1394 Motherboard
Hello. I have a Mimaki JV33BS Plotter (1.6m print width). Suddenly as from couple of weeks ago the plotter started printing some black dots everytime there is an image or color to print. This dots are...
Sounds like a cleaning issue.
Drivers for your printer can be downloaded from here:
http://www.mimaki.co.jp/english/download/uc_index.php
Manuals available here:
http://www.mimaki.co.jp/english/download/manual/#jv33
You may want to review page 158 of the PDF of your Operation Manual with respect to Troubleshooting when Image quality is poor. This document points to a number of sections with respect to specific cleaning requirements.
Dec 22, 2010 | LG Office Equipment & Supplies
The right type of motherboard for compaq presario 2200 pc
Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory (dynamic) - Does not include IEEE 1394 (Firewire) or TV-out (S-video) RoHS: Original 371793-001 System board (motherboard) - De-featured (DEF) for Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory (dynamic) - Does not include IEEE 1394 (Firewire) or TV-out (S-video) RoHS: Original 371794-001 System board (motherboard) - Full-featured (FF) with support for Intel Pentium M (Dothan and Trailing Bin) and Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory - With IEEE 1394 (Firewire) and TV-out (S-video) RoHS: Original 371794-001 System board (motherboard) - Full-featured (FF) with support for Intel Pentium M (Dothan and Trailing Bin) and Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory - With IEEE 1394 (Firewire) and TV-out (S-video) RoHS: Original
Mar 02, 2010 | HP Compaq Presario 2200 Notebook
Need manual for a d33007 m/b
Here is what I found on Web? Good Luck :0)
http://www.user-guides.co.uk/download/diagram/diagramd33007/diagram-d33007-motherboard.html
ASUS 1394 P3B 1394 IEEE 1394 Motherboard USERS MANUAL English
ASUS 1394 P3B 1394 IEEE 1394 Motherboard USERS MANUAL English Additional information on your ASUS Motherboards MainBoards. This manual has not been listed as either a service or user manual for your 1394 but may be of interest. 2 ASUS P3B 1394 4 ASUS P3B 1394 5 SOFTWARE SETUP 63 6 ASUS P3B 1394 6 SOFTWARE REFERENCE 7 APPENDIX 93 94 Part De ..... diagram d33007 motherboard ... lots more information here
Download And CD Available
Nov 11, 2009 | Computers & Internet
Need driver for Canon Mini DV ZR85
hi,if your camera has 1394 port then bye 1394 board , its so easy to use and too low cost ,so you can upload your video,
Aug 30, 2009 | Canon ZR85 Mini DV Digital Camcorder
I cannot transfer video from my Sharp VL-NZ50 to my PC
I had the same problem with the VL-NZ50. It wasn't the camera, it was the IEEE 1394 interface on the laptop(s) -
I tried two different ones, one XP, the other W7 64; both were HPs with on-board (OHCI compliant) TI
IEEE-1394 chipsets.
Then I tried a Gateway desktop (Vista) with an on-board Ricoh
IEEE 1394 interface: the VL-NZ50 was recongnized instantly, controlled by the PC and transferring video flawlessly.
If you want it to work with your laptop , try an Adaptec PCMCIA card (I've heard they work with this camera), they can be had for under $10.
Jul 11, 2009 | Sharp Viewcam VL-NZ50U Mini DV Digital...
No 1394 port located on MoBo as manual indicates. Is it mislabeled?
Return the motherboard to the place where you bought it, and have them explain the differences that you have observed.
May 30, 2009 | Foxconn 661FXME Motherboard
1394 Header pin-out
http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_25&products_id=57&osCsid=aeefcbb79e7dab18e3439d5d6c64cb0f
Ritmo PCI to USB + 1394 (CC-C15)
PPA USB2.0 + 1394 Combo PCI Card Model 1509
http://www.ppa-usa.com/products/usb/usb_pci/1578.htm
click on get pinouts for pdf file of card
Pinouts:
USB board is slikscreened with numbers but for reference
pin 1 ground is at top edge of board
and pin 5 plus 5v is towards gold connector edge
1. case Gnd (thick black)
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
Firewire: (8 pin header on board)
this board uses the 4pin firewire connection standard
NOT THE 6/9 PIN!!!! you only need to connect 4 pins
and if you have a thick case ground cable you can use it
pin 7 is towards bracket towards top edge of card
pin 8 is towards bracked towards gold edge connector
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
3 Case Gnd Thick Black (not thin black) if you have one
(white 30vdc) and (thin black, signal Gnd)
wires are not used
pins 1 and 2 are also unused for firewire connections
please note that this card has +12v on pin 2 instead of the
30v dc that a normal firewire 6 pin connection has
Sep 01, 2008 | Televison & Video
22 people viewed this question
k24674
jasbo
jasbo
