Question about Keurig K45 Elite Brewer
Coffee will not brew
Brew cycle not working
2 Suggested Answers
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
Why does my machine brew coffee very slowly almost dripping instead of brewing at regular cycle?
it might need cleaning solution to use is vinegar pour vinegar in it and turn it on let it fill the pot up hope this works good luck
Feb 26, 2015 | Cuisinart SS-700 - Single Serve Brewing...
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
Will not brew
mcdevito75 here, Your coffee maker may need cleaning, if so, fill the resovoir with WHITE VINEGAR and cycle thru 3 times, have clean or new filter in the machine, on the 3rd cycle stop machine for 30 minutes then resume, cycle thru2=-=3 more times if needed, after the vinegar cycle change filter or clean and cycle thru plain water 2--3 times or more to rinse out the vinegar.
Jul 10, 2010 | Kenmore KBC12 Coffee Maker
KeurigB50 Coffee Maker will not brew. Gets to the
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Apr 06, 2009 | Keurig B50 Coffee Maker
Braun coffee maker starts brewing, then stops after a few seconds
ijustam1
I have the same machine, Braun KF180 12 Cup Coffee Maker. In normal operation the brew cycle is stopped when the water reservoir is empty. The only way the coffee maker knows if that is true is when the water-brewing heater gets too hot. Your brewing heater is probably encrusted with calcium deposits if you have been heavily using the coffee maker. Vinegar will work but it is weak and you will have to cycle this solution through many many times. You should instead use "Lime Away" or "CLR" and let it sit there in a brew cycle or multiple brew cycles for a while. NOTE: Remove the filter when cleaning this way and when the brew cycle is complete, rinse thoroughly -- your taste buds will let you know if the machine is not rinsed thoroughly. -- Good Luck!!
Jan 22, 2009 | Braun FlavorSelect KF 180 Coffee Maker
Mr. Coffee won't brew - Mod. #ECX30118
IF YOUR HAVING ISSUES WITH THE ACTUAL BREW OR CLEANING CYCLE AND IT WILL NOT WORK, THERE IS NO TROUBLE SHOOTING THAT CAN BE DONE. MR COFFEE CARRIES A YEAR WARRANTY SO YOU SHOULD CALL THEM TO HAVE THEM REPLACE THE UNIT.
Jan 14, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
Braun Flavor Select will not brew coffee.
I assume You are talking about the water-brewing heater thereare two, the second is the heater that warms the coffee pot (I think!). When the water-heater is encrusted with calcium deposits it "thinks" that the water reservoir is emptyand ceases the brew cycle. water boils at 212 degF and the heater will go to a much higher temperature. I will leave you with the same solution as was posted to another problem that may have similar cause:
corvette2
Nov 16, 2008 | Braun FlavorSelect KF 180 Coffee Maker
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
Keurig K45 Elite Brewer Logo
110 people viewed this question
Top Keurig Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Keurig Kitchen Appliances - Other Expert? Answer questions, earn points and help others
