Question about Kenwood KID60B12 595 mm Stainless Steel Built-In Dishwasher 15 Place Settings, A Energy Rating
I keep getting an f5 code
I keep getting an f5 error code
Bravos XL F5 error
Here is a link to the error codes for your machine. There are several F5 error codes. F5 E4 Lid not opened between cycles F5 E3 Lid unlock fault F5 E2 Lid lock fault F5 E1
Lid switch fault
Oct 31, 2017 | Washing Machines
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Have a Kenmore 110.2632410 top load washer. Getting error code F5. Lid lock is just clicking.
The F5 error code indicates that the Central Control Unit (main machine control board) detects a temperature sensor resistance that is out of the normal range. The F5 error is normally caused by a failed NTC temperature sensor.
Jul 17, 2016 | Kenmore Washing Machines
I am trying to find a replacement part for a 24 Maytag Wall Oven, model CWG3100AAB. I am getting an F5 code, and I believe that means it is the ERC electronic control board.
Single/Double Wall Oven - Error Code/Message - F5 Error ...
www.maytag.com/...wall-oven...code...f5...code-f5-e0/PH7028/
MaytagHave a Maytag product question? Maytag's product help articles give answers to your frequently asked questions (FAQs).
Sep 30, 2015 | Maytag CWG3100AAB Wall Oven gas
My maytag oven keeps getting a F3/F5 code
F3 F5 error is for the temperature probe failure. Here is the part to order.
There is a video on that same parts page to show you how to replace the probe.
Keep me posted!
Jan 21, 2013 | Maytag MER6772 Gemini Electric Kitchen...
After cleaning, the oven will not work, it keeps flashing F5, whats the problem?
Hello & Welcome to FixYa
Error code F5 is a door latch failure and is displayed due to malfunction of door latch-switch assembly. First try to check the door latch switch, if fine then recommended repair is replacement of door latch-switch mechanism. Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | KitchenAid KESC300 Electric Kitchen Range
F5 E1 error code...i cant get the door unlocked and the beeper keeps going off.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#@#
Aug 23, 2010 | Whirlpool GR460 Electric Kitchen Range
F5 error
HI. I have researched this fault code and this is what we came up with.
F5 Board failure Replace control board (also called ERC or clock).
Mar 21, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool accubake oven error code
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
It may just be a door switch
Dec 18, 2007 | Whirlpool RBS305PDS Electric Single Oven
Kenwood KID60B12 595 mm Stainless Steel Built-In Dishwasher 15 Place Settings, A Energy Rating Logo
75 people viewed this question
Top Kenwood Dishwashers Experts
Owen Barnes
ashburton
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
