Question about Westell Wirespeed LiteLine 6100 (B9961001002) Modem
Westell 6100 problems
I hook up my westell 6100 to xbox to get xbox live but mtu fail
  • Anonymous Jun 19, 2008
    everytime i try to connect to xbox live with my xbox 360 it passes the network adapter test ans the ip adress and the dns test then when it gets to the mtu it fails everytime and i dont know what to do anymore....
  • Anonymous Jul 11, 2008
    I finally reached somebody at microsoft who could resolve this stupid problem. I plugged in my ethernet directly into the westell 6100 and kept failing the mtu test. The guy on the phone had me power cycle first which I did (disconnect from the wall the modem and the xbox for 30 sec. then, plug the modem back in first and wait for all lights to be back on. then, plug the xbox back in and run test. If mtu fails again as it did with mine, on the dashboard click restore to factory defaults then try and run test again. This did the trick for us! Now we are online. I then repeated the power cycling again because I wanted to try going through the airport extreme router to the modem to the xbox. It worked perfectly. just unplug everything again and repeat the process this time starting with the airport then modem then xbox. finally all is working!!!
We had the same issue. Here is how we fixed it. I had the xbox 360 plugged directly into the westell 6100 modem via ethernet cable. the mtu test failed everytime. I was extremely frustrated and called microsoft and verizon (dsl) about 10 times each and they kept giving me the wrong solution. (get a new modem, get a new server, pay us money and we'll figure it out etc...) Here is what a man at microsoft told me to do and finally it worked. Power cycle your equipment (unplug modem and xbox 360 for 30 sec.) then, plug in modem first and wait until all lights are back on. Then plug in xbox and run test. In my case mtu failed again. I was then instructed to go to my dashboard and restore xbox to factory default which I did and rerun the test. This time everything FINALLY passed. We were in business. I then decided to try connecting through my airport extreme router. I power cycled again starting with the airport then the modem then the xbox and ran the test and unbelievable as it sounds it all passed and my son is now sitting happily on the couch playing a game online with his xbox 360. This took away days of my life to get this simple thing done. I was given codes to change and change back on the computer, phone calls to everyone and the solution was so simple when you finally reach a knowledgeable person. Hope this will help save someone else the time I spent!
Posted on Jul 11, 2008
Bellsout6h and att are full of ****. they list a USB driver for the westell 6100 modem. its blatant false advertising. there IS NO DRIVER! when i download and open the zip its some "security catalog" and some some notepad installation nonsese that accompanies it.
they are a bunch of liars and morons. spread the word and maybe they will get a the message.
Posted on Aug 18, 2008
**** u ******* stop using cheap *** ****** DSL internet
Posted on Jun 11, 2008
  • 383 Answers
MS-DOS reg command help 1 - Failed 2 - Successful, the result compared is different ... Deletes the registry value MTU under MyCo on ZODIAC.
Linux and UNIX route command help The default is the device MTU minus headers, or a lower MTU when path mtu ... reject, install a blocking route, which will force a route lookup to fail.
Good Luck, Please dont for get to Vote/Thank You.
Posted on Dec 22, 2007
Not enough mtu to go to xbox live at hotel
An MTU is the largest physical packet size, measure in Bytes that a network is capable of transmitting.. If messages are larger than the MTU they are divided into smaller packets before they can be sent. All networks have different MTU's which the owner of the network set at what they want to set it at. 576 is a very common MTU if you connect through PPP. 1500 is the most common MTU for Ethernet connections. The Xbox Live system requires your network to have a certain Maximum Transmission Unit (MTU). MTU values are important to the performance of online games. If this test fails, you can adjust the MTU setting on your network router or equivalent device to resolve the problem. Xbox live requires the network you use to have a maximum MTU. This is key to online gamesing. If the MTU fails then you have to adjust the router you are using. If you cannot access the router to adjust the MTU the you will not be able to play online games.
Mar 22, 2011 | Microsoft Xbox 360 Console
Problems connecting to XBox live
I would strongly suggest to call Xbox techsupport for help. They will tell you what are the things taht you may try...its for free!!
Dec 08, 2008 | Westell Wirespeed LiteLine 6100...
Xbox 360 connecting to Xbox Live through Westell 6100 modem
I would greatly suggest to call Xbox live Techsupport. They will help you regarding connectivity issue and its for free!!!
Nov 23, 2008 | Westell Wirespeed LiteLine 6100...
Xbox live troubles!
hi ,
i went through ur problem and solution according to me is when u will open the routers page by 192.168.1.1 and there u will a tab under general settings and there would be an option for MTU ...
change that to mannual and change it to 1365 .....
well that is the only possible step
>>>>>> Do remember there is no special setting for MTU .... its just a tab there .....
IF u dont find that then u can send me the options that u see there ....
Oct 24, 2008 | Westell Wirespeed ProLine 6100 Router...
Xbox live cant connect mtu failed
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Aug 02, 2008 | Microsoft Xbox 360 Console
Xbox 360 live states MTU failed
for some reason i cant connect to live, it says that my mtu has failed. any surgesstions how i solve this??
May 18, 2008 | Microsoft Xbox 360 Console
Westell 327w
xbox live connection test MTU failed
Mar 12, 2008 | Microsoft Xbox 360 Console
Westell Wirespeed LiteLine 6100 (B9961001002) Modem Logo
1,586 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
