Question about Tripp Lite G1000U Intelligent LCD 1000VA 500W UPC Battery Backup with 8-Outlets ( Model) UPS System
Line voltage indicator false indication of voltage variations
Line voltage indicator shows voltage jumping from 118 to 135 while an external volt meter shows steady reading of 120
    Sergeant:
  • 272 Answers
Voltmeters usually read RMS on ac volts therefore 120 volts is OK while the indicator is reading peak volts. If unit is operational there is no problem.
Posted on Feb 16, 2015
Can I charge unit with a male to male on the 12 volt port asking about unit Stanley JS900CS Not Jump-N-Carry
Tool review: Jump-N-Carry jump starter -- Portable model ...
www.autoserviceprofessional.com/.../tool-review-jump-n-carry-jump-sta...
Jun 6, 2014 - The Jump-N-Carry's convenient charge indicator reveals the unit's stored voltage. ... By plugging the male/male adapter cable into the Jump-N-Carry ... This 12-volt DC port also can be used to power 12V accessories (up to 12 ...
Using The Unit As A 12 Volt Dc Portable Power Supply ...
Jan 01, 2016 | Cars & Trucks
I have a 2002 GMC Envoy, Quite frequently my charging light will come on and state that I only have 10 volts coming out and then all the sudden jump to 14 and work perfectly fine
How many mile are on you vehicle ? Have you ever had Alternator replaced before ? You alternator maybe starting to fail , brushes or the voltage regulator .
Charging System Indicators
BATTERY The IPC illuminates the battery indicator when the following occurs:
The PCM detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the PCM requesting illumination.
The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the body control module (BCM) indicating the system voltage.
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
The ignition is on, with the engine off.
BATTERY NOT CHARGING The IPC illuminates the battery not charging indicator in the driver information center when the following occurs:
It would be a good idea to have it checked out , most auto parts stores will do this for free !
Dec 29, 2015 | GMC Cars & Trucks
What is causing the battery to drain?
Running the car will drain the battery it if it's not charging ! An if your charging light is on it isn't charging ! Did you check power an grounds on the alternator ? There is a single heavier wire on the back of the alternator, this should have battery voltage ! You may want to take this to a ASE certified repair shop !
Functionality
With the ignition switch in the RUN position, voltage is applied through the warning indicator I circuit 904 (LG/RD) to the voltage regulator. This turns the regulator on, allowing current to flow from battery sense A circuit 35 (OG/LB) to the generator field coil. When the engine is started, the generator begins to generate alternating current (AC) which is internally converted to direct current (DC). This current is then supplied to the vehicle's electrical system through the output (B+) terminal of the generator.
Once the generator begins generating current, a voltage signal is taken from the generator stator and fed back to the regulator S circuit 4 (WH/BK). This voltage feedback signal (typically half the battery voltage) is used to turn off the warning indicator.
With the system functioning normally, the generator output current is determined by the voltage of the A circuit 35 (OG/LB). The A circuit 35 (OG/LB) voltage is compared to a set voltage internal to the regulator, and the regulator controls the generator field current to maintain the correct generator output.
The set voltage will vary with temperature and is typically higher in cold temperatures and lower in warm temperatures. This allows for better battery recharge in the winter and reduces the chance of overcharging in the summer.
Battery Positive Output (B+) Circuit 38 (BK/OG)
The generator output is supplied through the battery positive output (B+) terminal on the back of the generator to the battery and electrical system.
I Circuit 904 (LG/RD)
The I (ignition) circuit 904 (LG/RD) is used to turn on the voltage regulator. This circuit is powered up with the ignition switch in the RUN position. This circuit is also used to turn the charging system warning indicator on if there is a fault in the charging system operation.
A Circuit 35 (OG/LB)
The A (battery sense) circuit 35 (OG/LB) is used to sense battery voltage. This voltage is used by the regulator to determine generator output. This circuit is used to supply current to the generator field (rotor). The amount of current supplied to the rotor will determine generator output.
S Circuit 4 (WH/BK)
The S (stator) circuit 4 (WH/BK) is used to feed back a voltage signal from the generator to the regulator. This voltage is used by the regulator to turn off the charging system warning indicator. The S circuit is fed back externally on external mounted regulator generators.
Visual Inspection Chart Mechanical Electrical
  • Battery case, posts, hold-down clamp, cables and connections
  • Generator drive (serpentine) belt for condition and tension to make sure there is no slip between the belt and the pulley. For additional information, refer to Section 303-05 .
  • Battery charge
  • Generator pulley
  • Battery junction box (BJB)Mega Fuse
  • Battery junction box fuse:
    • 11 (20A)
  • Central junction box (CJB) fuse:
    • 30 (30A)
  • Circuitry
  • Charging system warning indicator
  • Cables
  1. Check the operation of the charging system warning indicator lamp (instrument cluster). Normal operation is as follows:
    • With the ignition switch OFF, the charging system warning indicator should be OFF.
    • With the ignition switch in RUN and the engine off, the charging system warning indicator light should be on.
    • With the engine running, the charging system warning indicator light should be off.
  1. Verify the battery condition. Refer to Section 414-01 .
Normal Charging System Voltages and Charging System Warning Indicator Operation Ignition Switch Position A Circuit 35 (OG/LB) S Circuit 4 (WH/BK) I Circuit 904 (LG/RD) Generator B+ Circuit 38 (BK/OG) Battery Engine to Battery Ground Charging System Warning Indicator Operation OFF 12 volts 0 volts 0 volts 12 volts 12 volts 0 volts Off RUN-engine off 12 volts 0 volts 1-3 volts 12 volts 12 volts 0 volts Illuminated RUN-engine running 13-
15 volts 1/2 battery voltage 13-
15 volts 13-
15 volts 13-
15 volts 0 volts Off
  1. If the customer concern is verified after the initial inspection, refer to the Symptom Chart to determine which tests to carry out.
    • The charging system warning indicator is on with the engine running (the system voltage does not increase)
    • Circuitry.
    • Voltage regulator.
    • Generator.
    • GO to Pinpoint Test B .
    Your whole problem is the alternator is not charging , a couple tests with a volt meter would tell you !
Aug 16, 2015 | 2001 Ford Expedition
Had my alternator rebuilt, but batteries still go dead.checked alternator shows charging at 11.9 volts then jumps to 15 volts after 2 minutes. is this the alternator
The alternator should be showing at least 15 volts when running! Anything lower would indicate the alternator is at fault, since you say it is showing below 12 volts even for 2 minutes indicates a fault.
there still could be a fault with the battery not holding its charge or something draining the battery like a wire shorting or trunk light staying on that is making the battery go flat!
Oct 05, 2014 | Cars & Trucks
1993 Jeep Wrangler charging problem
nothing wrong with the ECM unless it has the voltage regulator as part of the system
indicates faulty wiring and faulty alternator
have a load test done on the battery
have an auto electrician do a full charging system check
charging voltage should be 14.5-14.8 volts DC
battery voltage should be 12-13.5 volts dropping to 11 volts when cranking the engine
make sure that the drive belt tension is correct and the belt is in good condition
Dec 22, 2017 | 1993 Jeep Wrangler
Just replaced my alternator on my 2000 dodge dakota sport. jump started truck, while driving my voltage gauge jumped to over 18, had to turn on headlights and heater @max to get guage to decrease to...
the amperage of the alternator is immaterial as long as it is big enough to run the electrics of the vehicle
what is indicated here is that the new alternator required an external voltage regulator or a properly operating regulator to regulate the output voltage
battery voltage in a new battery fully charged is 13.2 volts dc and when the voltage regulator is working the controlled voltage is 14.5-14.8 volts dc
check how you wired up the alternator and have an accredited to test the charging circuit
Sep 13, 2017 | Cars & Trucks
Ammeter reads 18V with engine running.
I'm assuming you mean the charging voltage indicator. This is an indication of an incorrect charging voltage (too high, should be from 12.5 to 14 volts). This problem is most likely caused by a bad charging voltage regulator. There are two variations of the location of the regulator: 1) regulator is outside of the alternator and located on right side of the engine compartment on the wheel-well, below the starter relay or 2) The regulator is inside the alternator (in which case you'd have to replace the alternator).
Sep 01, 2011 | 1993 Ford F350
Component locator - cannot find the MAP sensor
TESTING-MAP- A vacuum line runs from the sensor mounted high to the intake manifold so it can measure the vacuum in the intake manifold. NOTE: Unusually high or low barometric pressures can generate a false DTC for the MAP sensor. If no driveability symptoms accompany the MAP code, do not replace it.
  1. Connect a MAP/BARO tester to the sensor connector and sensor harness connector. With ignition ON and engine OFF, use DVOM to measure voltage across tester terminals. If the tester's 4-6V indicator is ON, the reference voltage input to the sensor is okay. NOTE: The green light on the tester indicates that the VREF circuit is okay, 4-6 volts. A red light or no light indicates the VREF is either too low or too high.
  2. Measure the reference signal of the MAP sensor. If the DVOM voltage reading is as indicated in the table, the sensor is okay.
    1. Turn the ignition OFF.
    2. Disconnect the vacuum hose from the MAP sensor and connect a vacuum pump in its place.
    3. Apply 18 in. Hg of vacuum to the MAP sensor.
    4. If the MAP sensor holds vacuum, it is okay. If the MAP sensor does not hold vacuum, it must be replaced. Fig. 1: Manifold Absolute Pressure Sensor 84174020.gif
      Fig. 2: MAP sensor altitude/voltage output relationship 84174023.gif
      Fig. 3: MAP sensor frequency data 84174022.gif
Oct 15, 2010 | 1994 Lincoln Town Car
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
Tripp Lite G1000U Intelligent LCD 1000VA 500W UPC Battery Backup with 8-Outlets ( Model) UPS System Logo
133 people viewed this question
Top Tripp Lite Computers & Internet Experts
 Kevin Kershner
Kevin Kershner
Joseph Hoffmann
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
