Question about Nokia Lumia 520 Windows Phone Black
Activesync error code 85010018
Will not sync with server
ActiveSync Not Working
it might be trying to configure a microsoft exchange sync thats why its giving you that message you may want to try and uninstall activesync and download the lastest verizon 4.5. during install do not click on check box that says connect to exchange server and try to sync again, should get you taken care of,
Apr 06, 2009 | Motorola Mobility Q9m Smartphone
Microsoft Activesync not working properly
Have you tried synchronizing it to a new outlook profile?
Jun 17, 2008 | Microsoft Computers & Internet
Tip
Windows Mobile Activesync Setup
Configuring ActiveSync on a Windows Mobile Device
Before you start make sure the date and time are correct on the device.
  1. On phone 'Start' > 'Activesync'
  2. Click ‘menu’> 'Add Exchange server source'
  3. Enter your exchange server details
  4. Either untick or tick SSL depending on whether your server uses a secure certificate
  5. Click 'Next'
  6. Enter username
  7. Enter password
  8. Enter domain
  9. Click 'Next'
  10. Click 'Finish'
  11. Click 'Sync'
If the Exchange server requires the phone to have a certificate installed follow the steps below
You will need to have Activesync installed on your machine to complete this task. This can be downloaded from http://www.microsoft.com/windowsmobile/en-us/downloads/eulas/eula_activesync45_1033.mspx?ProductID=76
  1. Connect the phone to your PC using the data cable. A window will pop-up asking if you want to setup a partnership between your phone and your PC. Click CANCEL on this.
  2. Go to the location of the cetificate file & cut the file
  3. Open Microsoft ActiveSync on your computer and click Explore
  4. A new window should popup called "Mobile Device" or the name of your phone
  5. Copy the certificate into this window
  6. Disconnect your phone from the computer
  7. On your phone click start>programs>file explorer
  8. You should be able to see the certificate file>click on this file>after a few seconds a popup should say "One or more certificates were installed
  9. Try syncing your device again
on Dec 23, 2009 | Cell Phones
Serious Issue re ActiveSync 4.5, HTC Touch, WM6
by what i have seen when i have that problem i have deleted the partnership from active sync and then recreated the partnership, be sure that you have all your info backed up though because it will wipe it all off. That should help if not let me know
Mar 02, 2009 | HTC Touch HD Smartphone
ExchangeSever in the mobile active sync
Open ActiveSync on the phone and delete the partnerships.
Open ActiveSync on your computer when your phone is NOT connected and delete the partnerships.
You should now be back to square one.
Jan 23, 2009 | O2 Xda IIs Pocket PC
ActiveSync from my phone
Thinks jbrickman For ask Me !
Here is Another Problemes about This Phone
icon_ea.gif Error occurred accessing attachments. Verify attachment settings - Inbox Tools/Options/Storage. You should also verify that you have sufficient free storage space. icon_error.gif icon_ea.gif COM Error 80070002. icon_error.gif icon_ea.gif ..\CEOutlookTranslator\MapiFields.cpp 2333 icon_error.gif icon_ea.gif ..\CEOutlookTranslator\MapiFields.cpp 2423 icon_error.gif icon_ea.gif ..\CEOutlookTranslator\PFolder.cpp 817 icon_error.gif icon_ea.gif Error occurred while getting email field. icon_error.gif icon_ea.gif Subject of bad email: 080303 WebEx_Overview_.ppt icon_error.gif icon_ea.gif Bad email received: 3/5/08 6:00:27 PM icon_error.gif icon_ea.gif ..\CEOutlookTranslator\PFolder.cpp 679 icon_error.gif icon_ea.gif Error occurred while getting Inbox records, records Processed = 45 icon_error.gif icon_ea.gif COM Error 80070002. icon_error.gif icon_ea.gif ..\CEOutlookTranslator\PFolder.cpp 2957 icon_error.gif icon_ea.gif Error occurred while getting captured Inbox changes, changes Processed = 0 icon_error.gif icon_ea.gif COM Error 80070002.
And The SOlution Here IS :
The way to sync with Exchange Server (as detailed in the documentation that came with the phone and as I have it set up following those instructions) is:
- You go to the verizon wireless website, create your verizon account, enter all the details for your exchange server (address, username, password, etc).
- The VZW server pulls info from your exchange server and then the VZW server sends this info to your handheld.
You may want to call VZW tech support if you are having difficulty setting it up.
And Thanks
Aug 28, 2008 | Apple iPhone 3G
How to soft reset
There is small button that is usually in the battery compartment that you can press with a paper clip to soft reset the phone.
However, a soft reset will not fix your ActiveSync problem.
Here's what to do:
Open ActiveSync and go into the settings/options.
Delete any partnerships you see.
Now verify the following settings with your Exchange Administrator to make sure you have them right:
Server name: (a.k.a. your public server name)
Use SSL: Yes or No
User name:
Password:
Domain: (a.k.a. your private Windows Domain)
Now verify that your Exchange Admin has enabled ActiveSync for your account.
If the settings are correct and ActiveSync is enabled, you should now be able to set up working ActiveSync partnership.
Jul 04, 2008 | HTC S710 Smartphone
PDA will not sync with Microsoft Outlook.
Look here for Activesync error codes.
http://www.pocketpcfaq.com/faqs/activesync/exchange_errors.php
Mar 31, 2008 | Sony Ericsson K800i Cellular Phone
Try this, I read it on a microsoft.com forum.
Disconnect the device from the PC.
Open Activesync on the device.
Open the "Menu".
Click "Options"
Uncheck "E-mail" from Data you want to Sync.
Click "Done"
and re-sync devise to PC.
Once I did that, my contacts and all my appointments sync'd.
Hope that helps...
It seems tons of people have had this annoying issue.
Jan 19, 2008 | HTC Touch P3450 Smartphone
Avantgo
I am unsure myself after looking at this Pocket PC software matrix. Today I use AvantGo in my HP Jornada under PPC2000, but it seems it is not installed in the PPC 2002 software according to this matrix. Maybe there is a download you have to do, or settings for your server access you have to make?
Sep 13, 2005 | Dell Axim X5 Pocket PC
Nokia Lumia 520 Windows Phone Black Logo
255 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
