Question about GE Refrigerators
Ge model number tax4dncawh
Will not turn on
I need a model 15440, GE heavy duty digital timer manual
I do not recognize that timer model number.
The only place the model number appears is on link to fixya... indicating that the model number does not correspond to known product, or that some seller has renamed a timer so his product cannot be comparison-shopped.
Re-post question and attach photo
Most GE manuals appear on following link: open link to find same-similar timer
http://waterheatertimer.org/GE-timers-and-manuals.html
Gene
Water Heater Timers Save Money
Mar 13, 2015 | GE Hardware & Accessories
Ge mocrowave wotn cook, turn table wotn turn
I would suspect either the bottom or top door switch, or that switch's mount is loose, broken, or misaligned.
If you had posted the full model number, i probably could have told you which switch.
http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 05, 2013 | GE Microwave Ovens
Green power button flashes and beeps, then turns off
A model number is needed as there are hundreds of different GE sets that this could apply to---model number is on rear of set along with month and year set was made.
May 25, 2012 | GE Televison & Video
I'm using a ge universal remote and cnnot get the sylania model 6513 DF to work
Hello
You haven't described anything about the model number of GE remote. Eventhough it is universal remote, it will have a model number. Model number is necessary for us to give you correct codes. I hereby give you code for Sylvania combo. Check it with.
0456
The code for Sylvania TV/DVD combo with GE RM 24912 universal remote is:
456
Check this code [456] with your present GE remote. Sometimes it may match. OK.
Jun 04, 2011 | Sylvania 6513DF 13" TV/DVD
Ge washing machine wsxh208a1ww, The dial seems to get stuck during all cycles. If you go out and manually turn the dial one click it will keeping going. But it takes forever to do a load of laundry since...
The bad news is that you most likely need a new timer. I get mine (used) from e-bay after looking up the parts at "Sears Parts" by model number. Sears will sell you new parts by model number for your GE.
Be blessed.
Nov 08, 2010 | GE Washer Washing Machine Timer WH12X1000
GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Dec 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I HAVE A GE SPEAKER PHONE #29870 AND IT SAYS TO CHANGE THE BATTERY, TAKE THE BATTERY COMPARTMENT DOOR OFF AFTER REMOVING THE SCREWS. I FIND NO SUCH DOOR!!! ALSO IT DOES NOT SAY HOW TO TURN ON THE SPEAKER!!...
http://www.home-electronics.net/ge/pc/user-manuals.asp
I was looking for your model number on the GE website listed above - I found the "69" model and the "71" model. There may be more letters and numbers after the model number you gave
Example 29870GE3
Feb 27, 2009 | GE Lands Phones
GE dishwasher model # GSD2200Z02AD
yep you need a new timer part. on your search engine type in ge dishwasher model number then scroll down to find timer part number order it only if your can take broken one out if u cant then u need to call repairman.
May 13, 2017 | Dishwashers
G.E. Profile Microwave Model JVM2070SH01 turn table does not turn.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 02, 2008 | GE JEM25 Microwave Oven
GE Profile over the range microwave
It might be better to post this in the GE section, but I'll be happy to answer it here, too.
I would suspect a bad magnetron or high-voltage transformer, but it may be the turntable motor or an arcing stirrer.
If you can post back with the model number and a bit more detail on when and how it happens, we may be able to help you better.
Oct 23, 2007 | Microwave Ovens
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
