Question about DeLonghi DC312T 14-Cup Coffee Maker
TAKING THE BOTTTOM OFF SO I CAN SEE WHAT IS WRONG INSIDE
THE CONTROL PANEL WILL LIGHT UP WHEN PLUGGED IN BUT IT WILL NOT HEAT THE WATER.
How to remove evaporator cover from inside freezer admiral model hmg64184
Hello Joann Carter,
Make SURE you are electrically UN-PLUGGED.
The repair books tell you to remove all the side rails... pull the screws... Disconnect the temp sensor (if equipped in this area (here you want to start taking lots of pictures))...
The thing is... removing the side rails is usually un-necessary...
A little clever negotiating of the flexible panel... and it can be MANUVERED AROUND (my opinion)...
Further opinion... after a complete open air defrost
(never apply heat (anywhere))... FANS will help... It is possible to blow air UP the defrost drain... & clear it.
Again... Verify you are electrically UN-PLUGGED.
Then negotiate some warm water (never hot) into the
Evaporator-drain pan... Success will be immediately
apparent in the defrost pan...
May take a couple of tries... (straw or flex tubing).
Only failing that... pull out the back panel .
Hope this helps!
Aug 21, 2016 | Maytag Admiral 26 cu. ft. Side-By-Side...
89 Toyo Corolla SR5 Blows cold air even while overheating unless under mid-high RPM with Load
Heater core may be partially plugged. Also check the heater control valve to see if it's letting water into the heater core.
Jan 24, 2014 | 1989 Toyota Corolla 2 Door
Error code df on a simpson washing maching
The clue is in the water temp. light flashing. DF means that the temperature sensor is faulty. Replace it with a new one. Turn power off at wall. Remove the 3 screws & open panel. Sensor is plugged onto control board near the middle top of board & goes down into the base of the control panel at the middle where the water enters the machine. Unplug from the board taking care not to damage the pins on the board. Replace the new one making sure the o-ring is on it. Close up panel & turn power back on.
Oct 15, 2012 | Simpson Washing Machines
Roper washer will fill up with water and wont stop. What could be wrong?
The air hose from the tub to the pressure switch (inside the control panel) is either disconnected or plugged with debris. Open the control panel by removing 2 screws in the front corners and check for disconnected hose. Otherwise disconnect the hose and blow through it to see if it is plugged.
Jan 12, 2011 | Roper RAX4233PQ Top Load Washer
I have a Simpson encore 807 & screen displays DF what does that mean? It Still washes ok Beeps a lot though? can anyone help
The clue is in the water temp. light flashing. DF means that the temperature sensor is faulty. Replace it with a new one. Turn power off at wall. Remove the 3 screws & open panel. Sensor is plugged onto control board near the middle top of board & goes down into the base of the control panel at the middle where the water enters the machine. Unplug from the board taking care not to damage the pins on the board. Replace the new one making sure the o-ring is on it. Close up panel & turn power back on. All fixed!
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Washing Machines
Hot water runs out
there is panel on the side that you open by taking one screw off and looking inside , now you can turn the heat up and down with the switch inside the access panel.
Apr 26, 2010 | Reliance & 50gal Electric Water Heater
How do I control the ac/heater "under the hood" near firewall? The ac/heat do not switch out when knob turned. Had broken knob and cable replaced but problem lies deeper. Was told you can do this manually...
the ac/ heater controls is inside ur instrument panel/ u need to remove the instrument panel to give u access to check whats wrong with ur controls and u need set of tools to do that and be careful when removing panel boards as it easily breaks....
Apr 07, 2010 | 1995 Honda Accord
Freezer "leaking" cold water on floor
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Dec 06, 2008 | Frigidaire 14.1 cu. ft. / 399 liter...
Aprilaire 600 - change water panel light stays on
Turn the control knob to the test/reset position untill the change water panel light blinks to reset the change panel timer. Make shure the furnace is running calling for heat.Turn control knob to prior setting after resetting timer. Hope this helps.
Feb 16, 2008 | Aprilaire 600 Humidifier
Lf what does it mean?
Lf means long fill make sure your taps are on. or your filters in the hoses arn,t plugged in other words it is taking longer than 10 minutes to fill
Dec 11, 2007 | Kenmore Oasis HE 27082 Top Load Washer
DeLonghi DC312T 14-Cup Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
