Question about Samsung Refrigerators
Fridge is not dispensing water anymore
Fridge has suddenly stopped dispensing water
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 82 Answers
Water filter stopped up?
Posted on Apr 01, 2014
t0pc4t
  • 132 Answers
SOURCE: water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
Posted on Aug 15, 2008
Krames
  • 18 Answers
SOURCE: My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
Posted on Nov 15, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
SOURCE: Water Not dispensing from refrigerator door
I have a GE side by side refridgerator and have had the same problem 2 times. Under the freezer door is a the water tube which carries the water to the exit tube. You can locate the tube by removing the grill at base of fridge. Their you will see a connector connecting the 2 tubes. Seperate the tubes, take the feeder tube and hold it over a bowl, then you must close the door for the switch to work. Once door is closed, push dispenser switch on and if water flows into the bowl you are good from the main valve and your problem is in the door which is most likely a frozen line. It usually freezes near the bottom of the door. Reconnect tubing. Leave the door open for 10 minutes and use a hair dryer to that area so you can defrost the tubing. Be careful not to overheat the rubber gasket on the inside of the door because you will mess up the seal. After heating, close the door and retry switch. Good luck!
Posted on Jan 25, 2009
jumptrout51
  • 3361 Answers
SOURCE: freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Posted on Feb 28, 2009
Why has the water dispenser stopped working all of a sudden. Do the lines freeze up or is there an on off function on the control panel
Without knowing what make / model fridge it is nearly impossible to say , however, most domestic fridge have a water tank in the base of the food compartment which stores the water before going into the freezer dispenser. Have a look behind the crisper drawers for it. If the food compartment is too cold, this tank can freeze up and stop water from going into the dispenser. Is it still making ice? If so, the water valve which is normally 2 parts (1 for ice making and the other for water dispensing) may have failed.
Apr 09, 2015 | Refrigerators
Fridge and freezer suddenly not working only 1.5 yrs old
I guess the culprit in this case is the compressor.. Do you hear a sound when you are near the refrigirator.. it will be like a fan rotating at a high speed...
Mar 07, 2008 | GE GSL25LGTBS 25.4 Cu. Ft. Side-By-Side...
Whirlpool refrigerator WSF26C2EXF01 water dispenser not working
This sounds like the water inlet valve has gone bad.. First before u replace it check to see that you have water coming to back of fridge as it could be restricted causing no water to reach the fridge.
Apr 04, 2014 | Whirlpool Refrigerators
Water dispenser on fridge not working - water pressure fine, could the line be frozen and why would that start happening all of a sudden?
Check to see if the water reservoir in the bottom of the frig is frozen. If it is, you will need to turn the frig temp down.
Dec 04, 2012 | Refrigerators
The refrigerator water dispenser started running without pushing the device. It won't stop unless the freezer door is open. We were just sitting in the family room and all of a sudden the dispenser...
Pull the fridge out and look behind it. You're looking for the water line that could possibly have valve shutoff. If not, follow the line back to the source. Could be tapped under the sink, could go anywhere. You are attempting to shut off water to the fridge without shutting water off to entire home. Worst case scenario is if you can't locate the fridge shutoff and you can't get it fixed today and you don't want to leave the freezer door open, locate the main water shutoff for the house and shut it off over night. Hope this helps.
Jan 26, 2011 | GE Monogram Side by Side Refrigerator
GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Dec 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
GE Profile Performance - No water dispensing or ice making
NOT ENOUGH WATER PRESSURE AT WATERLINE OR WATER VALVE IS BAD AND NEEDS REPLACED
Jul 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser stopped working
Our fridge did this. Unplugged, plugged back in and it reset and is now working.
May 05, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
