Question about Philips Audio Players & Recorders
Only one channel
Phillips 222 has only one channel output
Can I connect a turntable to my Phillips LX900R system?
Assuming that the turntable has RCA audio output jacks, then yes you can. Just run the 2 channel RCA cable from the Output of the turntable to one of the AUDIO IN plugs on the back of the Philliips unit. Note which input you used and select it via the remote or on the front of the unit itself.
Feb 27, 2015 | Audio Players & Recorders
Cannot get a signal on my phillips t.v. iput and antenna n zenith digital converter box n say`s no signal
Hi. Convertor boxes have a preset channel output. This is either in the VHF region (channel 4) or somewhere in the UHF region (like most video's on channel 36 or 38). Switch on the convertor, and try a scan on your TV. You must be able to locate the output channel from the convertor. At least if this one is ok, or receiving.
Oct 05, 2014 | Televison & Video
Remote code for phillips dvd 711
I hope this helps
You need an OneForAll6 remote (URC 7560)
  1. Press DVD device button (set remote to DVD)
  2. Press and hold MAGIC until it flashes 2x
  3. Enter Setup Code (0539)
  4. Press MAGIC again
  5. Enter 085
  6. Enter 222 222 005 255
  7. (should be displayed)
  8. Press PLAY
Jun 13, 2014 | Coby DVD-224 DVD Player
How do i connect my pc to my phillips home theatre system through an hdmi cable
The best way is to connect your laptop to a spare HDMI input on your TV first, then use the AUX OUT from your TV to the AUX IN1 of the Phillips Home theatre system using a standard RCA cable.
The only catch with this is that you will have stereo analog audio, NOT digital surround. However, by pressing the "SURROUND" button of your Phillips HTS remote you can switch the audio output to multi-channel surround, stereo or party mode.
What is the model number of the TV you are using?
Oct 23, 2012 | Philips HTS-3565 Theater System
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
Unlocking Phillips PET722
I found this on a website devoted to unlocking DVD players.
  5. Enter 085
  8. Press PLAY
for the remote "SBC RU880":
  1. Press and hold 1 and 6 until SYNTH is displayed.
I hope you find this helpful
Dave
Nov 12, 2008 | Philips TV Tuner Video Capture PCI Card -...
DVD suround ystem
Sir,
This is due the the DVD issue, so please check the dvd audio support as well 5.1 channel enabled on your player to get the surround sound.
Please keep in mind that if the DVD supports 5.1 channel then only you can here the surround effect.
Aug 10, 2008 | Philips HTS-3555 System
Unlock Region Code for Philips 612 DVD Player
from http://www.dvddemystifiziert.de/codefree_en/philips.html
  5. Enter 085
  8. Press PLAY
karmor
Jan 12, 2008 | Televison & Video
32 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
