Question about Jeep 2006 Grand Cherokee Laredo
Whinning noise from rear end
Roaring noise from rear end
3 Suggested Answers
csmock132
  • 4669 Answers
SOURCE: has a roar in the rear end on drivers side ? what
Sounds like a wheel bearing
Posted on Apr 06, 2010
SOURCE: grinding and whinning noise suddenly
Have differential(s) serviced. Ensure correct friction modifier is added to gear oil. I have this problem every 40-50 or so thousand miles.
Posted on Feb 26, 2011
Have whinning noise when turning right or slowing down sounds like a power steering noise in rear end
A whinning noise while turning is an indication of a worn bearing. The extra pressure put against the bearing/race during the turn and the closing of a gap creates this noise.I would chech the axle bearings on the side of the truck on the outside the curve when you hear it. What I'm saying is if you hear it when you turn left....check the right side bearing
Sep 17, 2014 | 2004 Dodge Ram 1500
I have a 2009 altima. I hearing a roaring noise
In my 2005 Nissan Altima I experienced a roaring noise from the rear of the car. It ended up being the rear wheel bearings needed to be replaced. It appears that this is a common problem with Nissan Altima's & Maxima's of varying years even with fairly low mileage. This might be your problem.
May 13, 2014 | Cars & Trucks
Roaring noise from rear of 2002 hyundai santa fe
Let the seller listen to the noise from the rear that supposedly was replaced.
Jun 21, 2017 | 2002 Hyundai Santa Fe
Rear end on f-350 makes roaring noise. I checked oil level and it was ok. The oil seems to be very thin. Could wrong oil cause rear end noise?
Differential roaring noise is usually caused by a bearing that is worn or has pitting in the bearing race (half of bearing without rollers). A whining noise would be caused by worn ring and pinion gears. the roaring could be from the carrier bearings (two bearings holding the differential case to the axle housing) or fron the pinion bearings. The fluid is typically heavier but will seem thin when hot. The fluid isn't the causing of the noise but if the wrong fluid is in the differntial it could have caused the bearing to go bad which then causes the noise. good luck.
Apr 05, 2011 | Ford F-350 Cars & Trucks
We experience a lot of road noise in our 2007 RX 350. Very loud, rear passengers complain particularly. We put on new top of the line Toyota tires 235/55R 18's. Still emits a high pitched roaring from...
I had the same problem with my 2007 RX350. Had the tires replaced under warranty because of this roaring noise and still had the same problem. Replaced the original equipment brand tires with a set of new michelins and the noise went away. This was 10,000 miles ago.
Jan 21, 2011 | 2007 Lexus RX 350 FWD
When i put it drive and start to roll it is making a roaring sound either from the transmissoin or the rear end
hmm it could be a bad rear differential. i dont think it has anything to do with your transmission because when they go bad they dont make a roaring sound. they just either shift hard or make a grinding noise. it could also be your power steering pump, they make a roaring sound too. well i hope this helps you :)
Aug 23, 2010 | GMC Sierra 1500 Cars & Trucks
What would cause a loud roaring in the back seat of my 2001 Monte Carlo as I am driving?
That roaring noise should be a wheel bearing. Jack up the rear wheels and spin the tires by hand. You can hear a grinding noise if the noise inside the car is as load as you state.. The only other noise that will be like that is the differental gears inside the drive axle
Mar 28, 2010 | Chevrolet Impala Cars & Trucks
Roaring noise while moving
Sounds like you have a wheel bearing going out
Aug 01, 2009 | 2000 Chevrolet Suburban
AC/Heat Fan runs continuously and Rear end roaring noise
Sounds like the wheel bearing on the right rear hub may be defective, that would cause the noise if the tires are ok. As far as the fan goes not sure this isn't working as designed.
May 02, 2017 | 2005 Nissan Altima
Roaring in rear end
did the dealer look at the back of the car it shoud say FORD/FROD/FRAUD. GET THE FCUK RID OF IT.
Feb 07, 2009 | 2002 Ford ZX2
Jeep 2006 Grand Cherokee Laredo Logo
23 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
