Question about Air Tools & Compressors
Paasche 300T-000 Can't get solution to come out of bottle
I have a paasche d500sr that will not build up air
the Paasche web site has a dealer locator, you should be able to obtain parts from any dealer.
Sep 25, 2014 | Air Tools & Compressors
ERROR CODE E000019-000
this code is related with waste toner fullwhile removing the wast toner from bottle always clear the neck of the bottle from in side with cloth and restarting the machine after inserting the bottle. dont forget to clear the error in the service mode
Sep 27, 2012 | Canon imageRUNNER 2200
Should anything be done to 305t before it retires for the summer?
Yes, there is. Routine maintenance is important. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water and fill the tank with it. Run the humidifier until the tank is 1/2 empty. Then empty the remaining solution and refill the tank 1/2 way with Bottled Distilled Water and run it until it's empty. This will flush the entire system of the previous 50/50 solution. If you can access the fresh air intake, clean that using a can of compressed air with a straw nozzle (like you clean your computer with) to blow out the accumulated dust. Be sure the unit is completely dry before storing it.
If more folks would do this, they wouldn't have problems in the Fall & Winter.
Apr 12, 2011 | Honeywell HCM-300T Humidifier
I cant decide between two airbrushes i am thinking on ordering.I want a large cup gravity feed and right now am debating between the Badger 100LG and the Paasche Talon.Any comments would be great
I am not familiar with either brush, but they are both well known name brands. The Paasche will probably have more readily available parts for it than the Badger in case something breaks or you drop it. I myself use Iwata, BUT the parts are expensive.
It will boil down to which brush comes with what size tip/needle in accordance to what type of media you will be shooting. Thicker paints or stains will require a bigger tip and needle, thinner paints and stains, just the opposite. I hope this helps.
Feb 21, 2010 | Paasche Talon Gravity Feed Airbrush Set
I own a cannon 2800 copier and an error code of E000019-000 appeared what does tht mean?
waste toner is full or dirty window on bottle on the left side of copier then lower left cover 1 screw holds cover in. remove screw rmove cover pull out waste bottle empty the bottle and clean the 2 circle windows on the top of the bottle replace all turn copier off then on that should do it
Sep 11, 2009 | Canon Office Equipment & Supplies
Cannon IR 3100 CN Itermediate Transfer Belt error code E00070-000
The E00070-000 is not a ITB problem, but a full wastetoner. Open the front cover find the white bottle in the middle, remove the black screw, remove the cover over the top of the bottle and empty the bottle. Be sure to clean the top of the bottle so the sensor can see that the bottle is empty. Restart the copier.
Jun 04, 2009 | Canon iRC3100 Printer
Need a new paasche spray gun for bigger jobs
Anest-Iwata brand spray equipment has the most versatile line of airbrushes on the market. Im sure you will find one to meet your needs. well worth the money, it's all I spray
http://www.airbrush-iwata.com/
http://www.tcpglobal.com/airbrushdepot/iwata.aspx
check it out!!
Apr 07, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
32 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
